SWhetsel
Jan 24, 2011Aspirant
How to install Joomla on ReadyNAS - Walkthrough
To install Joomla 1.5 on the ReadyNAS, you’ll need to do the following. (detailed steps below) 1. Create a share on the ReadyNAS where you will run Joomla 1.5 and enable Internet access to the sha...
Halcyon1
Dec 08, 2014Aspirant
Hi Broadside, I think you didn't install the APT on your ReadyNAS.
This link contains the same instructions as Step 3 with added link to the APT add-on.
Not to revive such of an old thread, I have a slight different problem than Broadside. I'm actually stuck in Step 3.
When I ran:
I get:
Should I be trying to install all the listed dependency packages? Or just run
Sorry for the newbie questions. A bit of a Linux noob.
http://kb.netgear.com/app/answers/detail/a_id/12272/~/setting-up-a-php-cgi-environment
When I ran:
# apt-get update
# apt-get install libapache2-mod-php5
I get:
You might want to run `apt-get -f install' to correct these:
The following packages have unmet dependencies:
libapache2-mod-php5: Depends: libbz2-1.0 but it is not going to be installed
Depends: php5-common (= 5.2.0-8+etch9~bpo31+1.netgear1) but it is not going to be installed
Depends: ucf but it is not going to be installed
php5: Depends: php5-common (>= 5.2.0-8+etch9~bpo31+1) but it is not going to be installed
php5-mcrypt: Depends: php5-common (= 5.2.0-8+etch9~bpo31+1.netgear1) but it is not going to be installed
E: Unmet dependencies. Try 'apt-get -f install' with no packages (or specify a solution).
apt-get -f install? Or am I doing something wrong?
