Hawk321's avatar
Hawk321
Apprentice
Nov 05, 2021
How to mount a ReadyNas HDD under Win10
Hi,
I want to take a  Single HDD from the  ReadyNAS, no RAID,  and want to mount it via USB to  a Win10 PC.
I tried several programs like  Ext2 Volume Manager which sees the drive but cant mount it properly or   LFS from Paragon Software but  this software doesnt even show the drive.
So is there any  way to mount the drive? I want to transfer some data to it and then put it back into the NAS .  That because the network speed to fill it up is just very slow and I dont want it to take forever.
Thx
  • StephenB's avatar
    You'll need BTRFS (and possibly MDADM).  There are win10 betas for both.
    • Sandshark's avatar
      Sandshark
      Sensei
      You will need MDADM.  A ReadyNAS single-drive volume is a "one drive MDADM RAID1".  That is, it's actually half of a redundant pair, but the NAS has been told not to complain that it's not redundant.  It seems pretty clear that the reasoning is to allow expansion to actual redundancy instead of having to destroy and re-create.
      I've been meaning to run some experiments with the beta MDADM and BTRFS for Windows, but never seem to get to it.
      • Hawk321's avatar
        Hawk321
        Apprentice
        Would you mind to do so now and give us a how to?
        Had a look into it and was confused :/
ProSupport for Business
