Ullas
Feb 01, 2018Aspirant
How to recover data from readynas 31400
Hi, Please suggest how to recover data from readynas 31400. unfortunately i have deleted some data by mistake. model version: ReadyNAS 314 firmware: 6.9.2
Marc_V
Feb 01, 2018NETGEAR Employee Retired
Hi Ulas
Welcome to the community!
You may want to check your Snapshots from the date before you accidentally deleted the files.
Here is an article for that: Rollback a Snapshot
There are other recovery options as well from 3rd party apps that other users might suggest.
hope this helps!
Regards!
- SandsharkFeb 03, 2018Sensei
Since Rollback will destroy newer data, you may want to use Browse instead. The instructions above get you to the right point, just chose Browse instead of Rollback. You can select folders or files to restore. Alternately, you can choose "Allow snapshot access" in the share's snapshot setting and browse via an external device.
