Ullas
Feb 01, 2018Aspirant
How to recover data from readynas 31400
Hi, Please suggest how to recover data from readynas 31400. unfortunately i have deleted some data by mistake. model version: ReadyNAS 314 firmware: 6.9.2
Marc_V
Feb 04, 2018NETGEAR Employee Retired
Hi Ullas
We’d greatly appreciate hearing your feedback letting us know if the information we provided has helped resolve your issue or if you need further assistance.
If your issue is now resolved, we encourage you to mark the appropriate reply as the “Accept as Solution” or post what resolved it and mark it as solution so others can be confident in benefiting from the solution.
The Netgear community looks forward to hearing from you and being a helpful resource in the future!
Ullas
Feb 04, 2018Aspirant
Hi Marc_V
This device installed few days back, in that time i was not enabled snapshot. Pls help with some other way to recover data.
- Marc_VFeb 05, 2018NETGEAR Employee Retired
Hi Ullas
You may want to check ReclaiMe if it can recover lost/deleted data on the NAS or have it recovered by a specialist for a cost.
Other members might have better suggestions regarding recovering data.
Regards
- mdgm-ntgrFeb 05, 2018NETGEAR Employee Retired
It's important not to allow any writes to the volume after deleting data. Any writes to the volume will reduce the chances of successful data recovery.
In future I would suggest that you backup regularly. No important data should be stored on just the one device. Accidentally deleting data is an example of something that can go wrong.
