Johnny_bao
Jan 04, 2020Aspirant
How to recover my password of "admin" for RN426
Hi guys, I've lost my password of admin for RN426 (http://xxx.xxx.xxx.xxx/admin) and the site says "Sorry, password recovery has not been st on this device. Due to security reasons, password rec...
Jan 04, 2020Guru - Experienced User
An OS Reinstall will reset the password to admin
It also will reset the network configuration to use DHCP with no bonding, and it will disable volume quota (which can be reset via the setting wheel on the volume page of the web ui).
Instructions are on page 105-106 here: http://www.downloads.netgear.com/files/GDC/READYNAS-100/ReadyNAS_%20OS6_Desktop_HM_EN.pdf
FWIW, You might consider taping the admin password (or perhaps a hint) on the inside of the door of the NAS. There isn't much added security risk, since anyone who has physical access to the NAS can reset the admin password using the method above.
Johnny_bao
I've reinstall os for resetting password. but I found my storage had been reset too. and the data has been lost.....
- mdgmJan 05, 2020VirtuosoOnly a factory reset would wipe the data volume. Unless you chose that option by mistake most likely your data volume is offline.
For example perhaps your disks have become loose (e.g. when moving the unit to try to use the boot menu) and with no disks detected it booted into Safe Mode (safe mode is a new feature in recent firmware and has default admin credentials)
You may wish to power down and check the disks are properly inserted.
