Johnny_bao
Jan 04, 2020Aspirant
How to recover my password of "admin" for RN426
Hi guys, I've lost my password of admin for RN426 (http://xxx.xxx.xxx.xxx/admin) and the site says "Sorry, password recovery has not been st on this device. Due to security reasons, password rec...
Johnny_bao
I've reinstall os for resetting password. but I found my storage had been reset too. and the data has been lost.....
mdgm
Jan 05, 2020Virtuoso
Only a factory reset would wipe the data volume. Unless you chose that option by mistake most likely your data volume is offline.
For example perhaps your disks have become loose (e.g. when moving the unit to try to use the boot menu) and with no disks detected it booted into Safe Mode (safe mode is a new feature in recent firmware and has default admin credentials)
You may wish to power down and check the disks are properly inserted.
