daiji's avatar
daiji
How to remove the Readynas Pro CPUfan
Hello,
I asked if it was possible to remove the HDD from a broken Readynas Ultra6 and transfer it to a new Readynas.
I was unable to get a used Readynas, but finally was able to get a used Readynas Pro, so I tried it and it worked.
However, there is a new problem.
The CPU fan of this used Readynas Pro is unusually noisy.
I want to replace the CPU fan with a new one, but I don't know how to remove the fan from the heatsink.
I observed the CPU heatsink.
It seems that the fan and heatsink are held together by a U-shaped plastic hook. Can I lift up this plastic and remove the fan?
I am worried that the hooks might break if I do it forcefully.
    • daiji's avatar
      daiji
      I'm sorry.
      It was an unintentional double post.
      I don't know how to delete the POST,
      but please delete this post > Netgear rep.
ProSupport for Business
