SmellyFella
Oct 09, 2023Aspirant
How to Setup a readyNas RN102 2023
I have recently bought a second hand readynas with intent to start a little home media server/cloud storage for my files. Im having a hard time trying to work out to to start this now with the knowle...
SmellyFella
Oct 10, 2023Aspirant
Id love to have it set up as a plex storage mostly as I have a 2tb hard drive in the nas at the moment. And just to use it as extra storage for my household. Ive tried setting it up with raidar but it cant scan for it. so at the moment I have no idea how to tap into it?
Thanks for the fast reply
Oct 10, 2023Guru - Experienced User
SmellyFella wrote:I've tried setting it up with raidar but it cant scan for it. so at the moment I have no idea how to tap into it?
Are you seeing it in your router's attached device list?
Also, try powering down and removing the disk. Then power up and see if RAIDar finds it (it should report a no-disks status).
Internet security software (including some antivirus packages) can interfere with RAIDar, so maybe also try disabling those.
