SvPir8
Dec 27, 2015Aspirant
How to Transfer Share/Folder from one box to another
I have 2 RN102 boxes and i am looking to transfer 1 folder from box 1 to box 2. I want to do this with out using my laptop as the middle man for the data and i am new to this whole thing.
I setup the FTP and installed MonstaFTP thinking that it would let me connect to one box and download to the other box but that didn't work like i had thought.
Any help is welcome.
Thanks
Ok, i got it...
the original post said to setup the back-up on the receiving box. That was where the mistake was made.... it should have been a back-up coming from the sending box.
I tried resetting the permissions when doing the back-up from the receiving box... Didn't work. Once i setup the back-up from the sending box everything worked great through NFS
So... Mission Accomplished.
Thanks!
Set up a backup job in the receiving NAS. Use either rsync or NFS (and enable that for the source share).
- SvPir8Aspirant
Ok.. the 1st attempt was working but didn't copy the entire folder. It got about 33% through and stopped. The receiving box says that the back-up was completed and i checked the log and saw no errors. Out of 1147 files only 382 were moved. I don't know if there was a quota or some setting that stopped the transfer. I have since started the back-up again to see where it ends up.
Are these boxes able to be connected together with a USB cable and have them recognize each other? If so i would probably just do that instead.
No.
Odd. Did you try resetting the share permissions on the source?
- SvPir8Aspirant
Thanks! i wasn't able to get Rsync to work but NFS is working right now. Now i guess it's time to sit back and wait.
