xtrips1
Feb 11, 2013Aspirant
How to upgrade memory on Pro (x86)?
Hello, At first my Pro came with 2x500Mb memory sticks. Then a few years back I wanted to upgrade to 2x2Gb sticks but the Pro wouldn't accept them. I don't remember which FW version i was running t...
mdgm-ntgr
Feb 25, 2013NETGEAR Employee Retired
Take a look at the community hardware compatibility list for memory: http://www.readynas.com/forum/viewforum.php?f=110
You can actually put 2x4GB sticks in a ReadyNAS Pro.
There is a VGA header on the motherboard as mentioned here: http://www.readynas.com/forum/viewtopic.php?p=223230#p223230. Some old graphics cards came with a VGA header cable that works with that header. If you run the "Memory Test" boot option the progress should be shown on a connected display.
