JBDragon1
Sep 16, 2016Virtuoso
How to Upgrade the CPU and RAM in a ReadyNAS 516
Well I have done it. It seems to be working great. I've ran a few basic tests and you really don't get a idea of the differance without accessing it. you can notice the speed Improvment. Accessin...
JBDragon1
Sep 17, 2016Virtuoso
So far the speed boost is nice. I tried playing the 4K video file I had that was buffering over and over again. It was unwatchable. Now it plays perfect transcoding from 4K to 1080P. Plex is loading up Image art faster and videos are starting a little quicker. It looks like a worthwild upgrade. A good way to to get more life from your NAS.
ifixidevices
Sep 30, 2016Luminary
Very nice write up. I did this with my RN516 a while ago. Definitely a big improvement and it's way cheaper than buying a RN716.
I got the 516 for $300 because it has a small dent in the casing and the processor for around $140 and memory was about $80. Everything sourced from eBay.
- JBDragon1Oct 08, 2016Virtuoso
I got my ReadyNAS 516 on Amazon by a 3rd party seller, used for $500. The Ram frm Amazon, and the CPU from ebay. It's the CPU you want to watch out for on ebay. Watch out for the engineering samples whch are not suppose to be sold!!! You kind find them all over ebay from China for a cheaper price. I wasn't going to risk it.
https://en.wikipedia.org/wiki/Engineering_sample
You really got a great deal overal. I was looking all over and couldn''t find anyone that said they actually DID it and showed how they did it. It was hints here and there trying to piece it togeather enough to go ahead and try it myself. In the end it was pretty simple for me. I built my high end Windows PC I'm on now, so it's nothing new to me.
But I wanted to make it simpler for others to see how I went about it. What parts you need to do it. You need to know the correct CPU and RAM and what is required to swap the CPU. You can't just pull it, throw in another and that's it. It's the little things that make the difference. It's still running great for me. It's noticably faster!!! It was worth it.
Find a great deal on a ReadyNAS 516, here's a way to get more power out of it. Have one already and want more power, here you go! It works!!!
- funglennJan 04, 2017Luminary
is there a list of CPUs you can use? I relize that E3-1265 V2 is the one in the 716, but can i use others in the E3-12xx V2 line? i see the vary in price wildly and all seem to be better than the i3 in the 516.
thanks
- mdgm-ntgrJan 05, 2017NETGEAR Employee Retired
There is a limit on the TDP. If you get a CPU that gets too hot then it won't be able to be cooled properly.
