NASguru
Nov 01, 2016Apprentice
How to verify PHP and MySQL version on NAS
Does anyone know if the newer ReadyNAS ship with PHP and MySQL installed? And if so, how can you verify the version? I saw a post online about PHP as follows: Distro PHP Version Ubuntu 12.04 5...
- Nov 01, 2016
-which php and which mysql returned nothing.
-find -iname "php" and find -iname "myqsl" found nothing
-dpkg --list did not include anything related to mysql or php
Nov 01, 2016Guru - Experienced User
NASguru
StephenB wrote:-which php and which mysql returned nothing.
Got it so is there any how-to guides on installing the latest versions? It seems everything in the App store is using much older version or in limbo since the upgrade to OS 6.6.
- StephenBNov 01, 2016Guru - Experienced User
Not that I've seen. It would be useful to have up-to-date apps to install these (or at least a how-to).
- NASguruNov 01, 2016Apprentice
StephenB wrote:
NASguru wrote:Got it so is there any how-to guides on installing the latest versions?
Exactly my point and I'm actuall surprised that's not the case. Unfortunately, I'm not savvy enough to grab the source codes from GitHub and compile/port them over or I would create my own App for the store. I can probably Google enough and fumble through a manual installation but even then I may have only limited success. :smileysad: Is there a process to make a recommendation to Netgear to bundle this with the next update?
