CutterK
Jul 20, 2011Aspirant
HP P1005 problems
Hi all I hope someone can help me with this. I have a HP P1005 laser printer connected to my RND4000. It works well for a few days then it wont print. it shows as running fine in all areas just w...
PapaBear1
Jul 21, 2011Apprentice
Are you running the driver that was on the CD or the latest from the HP website.
Does the printer act the same regardless of which PC is generating the print job?
I noted in research, that this particular printer was not highly rated and a similar problem was quoted in user reviews. No mention of whether they were using a print server or a direct connection to a PC.
What do you have to do to get the printer to work?
Does rebooting the NAS do it?
