Katrinafiles
Feb 20, 2016Aspirant
I want qbittorrent to work on readynas (I don't understand the lingo!)
I installed Qbittorrent from the app that came with the readynas 204. After it wouldn't start downloading, I messed with the port settings. Now when I try to login to it again, it says data not found...
Katrinafiles
Feb 21, 2016Aspirant
I removed it and reinstalled it. Then when I click it now, it says 404 not found.
- KatrinafilesFeb 21, 2016Aspirant
I also have a problem with plex now. It won't let me uninstall it. I get stuck when I try to. Currently, it's not working either because of a failed update firmare.
- mdgm-ntgrFeb 21, 2016NETGEAR Employee Retired
Can you send me your logs (see the Sending Logs link in my sig)?
I just sent it.
I notice in the log it says user katrinafiles deleted every time I try to join readycloud. It gives me a registration error every time I try to link my readynas to readycloud.
