Katrinafiles
Feb 20, 2016Aspirant
I want qbittorrent to work on readynas (I don't understand the lingo!)
I installed Qbittorrent from the app that came with the readynas 204. After it wouldn't start downloading, I messed with the port settings. Now when I try to login to it again, it says data not found...
Katrinafiles
Feb 21, 2016Aspirant
I removed it and reinstalled it. Then when I click it now, it says 404 not found.
Katrinafiles
I also have a problem with plex now. It won't let me uninstall it. I get stuck when I try to. Currently, it's not working either because of a failed update firmare.
- mdgm-ntgrFeb 21, 2016NETGEAR Employee Retired
Can you send me your logs (see the Sending Logs link in my sig)?
- KatrinafilesFeb 21, 2016Aspirant
I just sent it.
I notice in the log it says user katrinafiles deleted every time I try to join readycloud. It gives me a registration error every time I try to link my readynas to readycloud.
Your NAS is not connected to the internet.
Can you verify that the DNS server addresses specified are accurate?You might wish to add e.g. 8.8.8.8
