Katrinafiles
Feb 20, 2016Aspirant
I want qbittorrent to work on readynas (I don't understand the lingo!)
I installed Qbittorrent from the app that came with the readynas 204. After it wouldn't start downloading, I messed with the port settings. Now when I try to login to it again, it says data not found...
Katrinafiles
Feb 21, 2016Aspirant
I also have a problem with plex now. It won't let me uninstall it. I get stuck when I try to. Currently, it's not working either because of a failed update firmare.
mdgm-ntgr
Feb 21, 2016NETGEAR Employee Retired
Can you send me your logs (see the Sending Logs link in my sig)?
- KatrinafilesFeb 21, 2016Aspirant
I just sent it.
I notice in the log it says user katrinafiles deleted every time I try to join readycloud. It gives me a registration error every time I try to link my readynas to readycloud.
- mdgm-ntgrFeb 21, 2016NETGEAR Employee Retired
Your NAS is not connected to the internet.
Can you verify that the DNS server addresses specified are accurate?You might wish to add e.g. 8.8.8.8
- KatrinafilesFeb 22, 2016Aspirant
I'm using my ISP's DNS. I've also tried google's DNS and it did not work. How do I check if I'm connected to the internet?
