CDStoneley's avatar
CDStoneley
Imminent Failure? Replace now, or wait?
I have my old ReadyNAS NV+ (v1) which until recently was limping along quite happily with the Seagate ST2000DL003 drives. In the last two-three months, the middle two (not surprising, given they consistently run hotter) disks both popped their clogs after more than the obligatory service. I am running radiator 4.1.14 and raidar 4.3.8.
Question - my disk 1 (still the Seagate) looks like it's next judging by the ATA Error Count... I have bought 4 replacement WD20EFRX, and disks 2 & 3 seem quite happy (3 replaced most recently). Should I bite the bullet and replace the other two pre-emptively, or wait?
I have the ReadyNAS set up on a APC UPS, so voltage in is clean, and the unit has battery backup and clean shut-down configured.
SMART Information for Disk 1
Model:ST2000DL003-9VT166
Serial:6YD0L136
Firmware:CC32
SMART Attribute
Spin Up Time0
Start Stop Count1091
Reallocated Sector Count11408
Power On Hours22095
Spin Retry Count0
Power Cycle Count1091
Runtime Bad Block0
End-to-End Error0
Reported Uncorrect5
Command Timeout0
High Fly Writes0
Airflow Temperature Cel35
G-Sense Error Rate0
Power-Off Retract Count1090
Load Cycle Count1091
Temperature Celsius35
Current Pending Sector0
Offline Uncorrectable0
UDMA CRC Error Count0
Head Flying Hours75355201230509
Total LBAs Written2892396288
Total LBAs Read632636578
ATA Error Count5
Extended Attribute
Hot-add events0
Hot-remove events0
Lp stat events64
Power glitches0
Hard disk resets0
Retries0
Repaired sectors0
SMART Information for Disk 4
Serial:6YD01J7P
Firmware:CC32
SMART Attribute
Spin Up Time0
Start Stop Count1088
Reallocated Sector Count0
Power On Hours22153
Spin Retry Count0
Power Cycle Count1089
Runtime Bad Block0
End-to-End Error0
Reported Uncorrect0
Command Timeout1
High Fly Writes2
G-Sense Error Rate0
Power-Off Retract Count1088
Load Cycle Count1089
Head Flying Hours229419973105375
Total LBAs Written2195701919
Total LBAs Read3411300727
ATA Error Count0
Extended Attribute
Hot-add events0
Hot-remove events0
Lp stat events6
Power glitches0
Hard disk resets0
Retries0
Repaired sectors0
  • StephenB's avatar
    5 ATA errors isn't that big a deal, but 11408 reallocated sectors is.  Replace disk 1 right away.
    • mdgm-ntgr's avatar
      mdgm-ntgr
      NETGEAR Employee Retired
      I would replace both starting with disk 1 (wait for resync to complete before replacing next disk).
      That SeaGate disk model is known to have a firmware bug and unfortunately there is no firmware update available for disks with CC32 firmware.
ProSupport for Business
