Peter_Zulof
Mar 21, 2016Guide
Import users from active directory
HI All, I have a problem importing users from active directory, despite that the operation completed successfully but i cant found users after authentication succeed. It was working fine, then i...
Peter_Zulof
Mar 24, 2016Guide
Thank you JennC,
yes i tried to refresh AD, and tried several browsers, you can see screen shots below :
Best
JennC
Mar 24, 2016NETGEAR Employee Retired
Hello Peter_Zulof,
How many users are you importing? And what is the current FW version of the NAS?
- Peter_ZulofMar 26, 2016Guide
Hi again,
Its about 35 user, i am using 6.4.2
- mdgm-ntgrMar 28, 2016NETGEAR Employee Retired
Can you send in your logs (see the Sending Logs link in my sig)?
- Peter_ZulofMar 29, 2016Guide
Dear Sir,
how can i send you attached logs file?
Best
