Colossal-Media's avatar
Oct 23, 2018
Increasing Speed on RN3138
We currently have a Ready Nas RN3138. Each bay with 4x 4TB Drives running X Raid and Raid 5. Were looking to whatever we can to increase the speed for server connectivity.
What would be the best way to upgrade the RN3138 to SSDs or myabe partial SSDs?
Which Bays should the SSDs be installed etc.
Also was wondering if I trunk 2 nics together it will increase the speed.
  • StephenB's avatar
    What speeds are you seeing?
    How many simultaneous users to you typically have?
    Is the concern the large file transfer speeds, or small files/folder browsing?
    NIC teaming can help if you have lots of users.
    There are two approaches to using SSDs
    • Colossal-Media's avatar
      Colossal-Media
      On Average we have about 15-20 users at a time connected to the server.
      Most users are accessing Excel files , QuickBook Files, and Adobe illustrator files.
      We have concerns with large file transfer reads, along with small files/folder browsing
      I know editing video content over this system would not be affected.
      Were currently using Egnyte for cloud storagage which syncs to our Ready NAS.
      • StephenB's avatar
        It's always a good idea to check the disk health when you are seeing performance issues - especially if they are new.  So perhaps look at the SMART stats in disk_info.log  Also, check the network stats in network_settings.log and your switches.
        Are you using link aggregation?  If so, how is it set up?
        Also, are any shares configured to use "strict sync"?  That will hurt performance.
        Can you run NasTester and report the results? http://www.808.dk/?code-csharp-nas-performance
        Ideally you'd get results when the NAS is idle, and also when it is under it's normal load.
ProSupport for Business
