TikTok90
Sep 09, 2013Star
Incremental Upgrades
Hi, After a bit of advice. I'm thinking of getting a RN104. I currently have a Duo running two 500Gb drives. I'm looking to initially put in 2x 1Tb drives, and then transfer the information acro...
mdgm-ntgr
Sep 09, 2013NETGEAR Employee Retired
If using X-RAID2 you wouldn't be able to add the 500GB disks after installing 1TB ones. You would need to add 1TB or higher capacity disks.
