TikTok90
Sep 09, 2013Star
Incremental Upgrades
Hi, After a bit of advice. I'm thinking of getting a RN104. I currently have a Duo running two 500Gb drives. I'm looking to initially put in 2x 1Tb drives, and then transfer the information acro...
Sep 10, 2013Guru - Experienced User
You could back up the duo, and install all 4 drives. Then restore the data.
If you have an enclosure you can backup to one of the 1 TB drives temporarily, and then add it into the RN104 later.
