TikTok90
Sep 09, 2013Star
Incremental Upgrades
Hi, After a bit of advice. I'm thinking of getting a RN104. I currently have a Duo running two 500Gb drives. I'm looking to initially put in 2x 1Tb drives, and then transfer the information acro...
Sep 11, 2013Guru - Experienced User
xraid-2 only supports a single array.
However, if you choose flexraid you can set up 2 arrays with the RN104.
