tim_hamblin
Jan 07, 2012Aspirant
Initial findings with new Duo V2
I've already sent a few posts about my initial experience with the new Duo V2, but thought it easier to put it into one feedback post... I've previously used the ReadyNAS Duo (V1) for a few years, ...
tim_hamblin
Jan 08, 2012Aspirant
Raising a Ticket now - started to copy data back onto Duo V2 - Volume Scan comes back with errors:
fsck from util-linux-ng 2.17.2
e2fsck 1.41.14 (22-Dec-2010)
Pass 1: Checking inodes, blocks, and sizes
Inode 28611385, i_blocks is 585088, should be 585096. Fix? yes
Inode 28611393, i_blocks is 717224, should be 717232. Fix? yes
Inode 28611434, i_blocks is 626624, should be 626632. Fix? yes
Inode 28611438, i_blocks is 420616, should be 420624. Fix? yes
Inode 28611445, i_blocks is 623528, should be 623536. Fix? yes
Inode 28611515, i_blocks is 726496, should be 726504. Fix? yes
Inode 28611538, i_blocks is 501496, should be 501504. Fix? yes
Inode 28611585, i_blocks is 693720, should be 693728. Fix? yes
Inode 28611620, i_blocks is 853008, should be 853016. Fix? yes
Inode 28611629, i_blocks is 558904, should be 558912. Fix? yes
Inode 28611912, i_blocks is 355952, should be 355960. Fix? yes
Inode 28639706, i_blocks is 426088, should be 426096. Fix? yes
Inode 28639716, i_blocks is 585088, should be 585096. Fix? yes
Inode 28639724, i_blocks is 717224, should be 717232. Fix? yes
Inode 28639755, i_blocks is 606064, should be 606072. Fix? yes
Inode 28639803, i_blocks is 726496, should be 726504. Fix? yes
Inode 28639876, i_blocks is 863200, should be 863208. Fix? yes
Pass 2: Checking directory structure
Pass 3: Checking directory connectivity
Pass 4: Checking reference counts
Pass 5: Checking group summary information
/dev/mapper/c-c: ***** FILE SYSTEM WAS MODIFIED *****
/dev/mapper/c-c: 23121/30285824 files (0.9% non-contiguous), 22901818/484573184 blocks
