tim_hamblin
Jan 07, 2012Aspirant
Initial findings with new Duo V2
I've already sent a few posts about my initial experience with the new Duo V2, but thought it easier to put it into one feedback post... I've previously used the ReadyNAS Duo (V1) for a few years, ...
mdgm-ntgr
Jan 22, 2012NETGEAR Employee Retired
PapaBear wrote: tim_hamblin - you say the model you received from Netgear as replacement on your RMA is part number RND2000-200WWB. The 200 would indicate a v2.
Unfortunately a number of v1 units were labelled RND2000-200 (Have a look at How to tell whether I have a Duo v1 or Duo v2 or NV+ v1 or NV+ v2), which is very confusing I know. The WWB is for refurbished.
Now this may have changed but as the Duo v2 is a pretty new product there would either be no refurbished units or a very limited supply of them. If NetGear has no refurb v2s they should replace with a new unit.
