tim_hamblin
Jan 07, 2012Aspirant
Initial findings with new Duo V2
I've already sent a few posts about my initial experience with the new Duo V2, but thought it easier to put it into one feedback post... I've previously used the ReadyNAS Duo (V1) for a few years, ...
efxi
Jan 24, 2012Aspirant
I'd like to reiterate the Volume Scan (i_block errors) problem. Have the same thing here. My ReadyNas Duo v2 is on an UPS, all graceful shutdowns, no weirdness. Also have a problem (sometimes) when copying large (1GB) files to the NAS. "Disk Full". Restart copying and everything is ok. Here's my log for the i_block errors:
***** File system check performed at Tue Jan 24 15:50:50 EST 2012 *****
fsck from util-linux-ng 2.17.2
e2fsck 1.41.14 (22-Dec-2010)
Pass 1: Checking inodes, blocks, and sizes
Inode 17727538, i_blocks is 717976, should be 717984. Fix? yes
Inode 17727539, i_blocks is 717944, should be 717952. Fix? yes
Inode 17727540, i_blocks is 717968, should be 717976. Fix? yes
Inode 17727541, i_blocks is 717912, should be 717920. Fix? yes
Inode 17727542, i_blocks is 717928, should be 717936. Fix? yes
Inode 17727543, i_blocks is 717904, should be 717912. Fix? yes
Inode 17727544, i_blocks is 717944, should be 717952. Fix? yes
Inode 17727545, i_blocks is 717976, should be 717984. Fix? yes
Inode 17727546, i_blocks is 717968, should be 717976. Fix? yes
Inode 17727547, i_blocks is 717984, should be 717992. Fix? yes
Inode 17727548, i_blocks is 717968, should be 717976. Fix? yes
Inode 17727549, i_blocks is 717896, should be 717904. Fix? yes
Inode 17727550, i_blocks is 717960, should be 717968. Fix? yes
Inode 17727551, i_blocks is 717976, should be 717984. Fix? yes
Inode 17727552, i_blocks is 717976, should be 717984. Fix? yes
Inode 17727553, i_blocks is 717904, should be 717912. Fix? yes
Inode 17727554, i_blocks is 717904, should be 717912. Fix? yes
Inode 17727555, i_blocks is 717896, should be 717904. Fix? yes
Inode 17727556, i_blocks is 717912, should be 717920. Fix? yes
Inode 17727557, i_blocks is 717960, should be 717968. Fix? yes
Inode 17727558, i_blocks is 717968, should be 717976. Fix? yes
Inode 17727559, i_blocks is 717912, should be 717920. Fix? yes
Inode 17956866, i_blocks is 717488, should be 717496. Fix? yes
Inode 17956867, i_blocks is 717480, should be 717488. Fix? yes
Inode 17956868, i_blocks is 717560, should be 717568. Fix? yes
Inode 17956869, i_blocks is 717536, should be 717544. Fix? yes
Inode 17956870, i_blocks is 717544, should be 717552. Fix? yes
Inode 17956871, i_blocks is 717120, should be 717128. Fix? yes
Inode 17956872, i_blocks is 717568, should be 717576. Fix? yes
Inode 17956873, i_blocks is 717624, should be 717632. Fix? yes
Inode 17956874, i_blocks is 717280, should be 717288. Fix? yes
Inode 17956875, i_blocks is 717592, should be 717600. Fix? yes
Inode 17956876, i_blocks is 717536, should be 717544. Fix? yes
Inode 17956877, i_blocks is 717528, should be 717536. Fix? yes
Inode 17956878, i_blocks is 717640, should be 717648. Fix? yes
Inode 17956879, i_blocks is 717072, should be 717080. Fix? yes
Inode 17956880, i_blocks is 717640, should be 717648. Fix? yes
Inode 17956881, i_blocks is 716720, should be 716728. Fix? yes
Inode 17956882, i_blocks is 716688, should be 716696. Fix? yes
Inode 17956883, i_blocks is 717464, should be 717472. Fix? yes
Inode 17956884, i_blocks is 717656, should be 717664. Fix? yes
Inode 17956885, i_blocks is 717328, should be 717336. Fix? yes
Inode 17956886, i_blocks is 717184, should be 717192. Fix? yes
Inode 17956887, i_blocks is 717592, should be 717600. Fix? yes
Inode 17956888, i_blocks is 717504, should be 717512. Fix? yes
Inode 17956889, i_blocks is 717464, should be 717472. Fix? yes
Inode 18087938, i_blocks is 717288, should be 717296. Fix? yes
Inode 18087939, i_blocks is 717328, should be 717336. Fix? yes
Inode 18087940, i_blocks is 717608, should be 717616. Fix? yes
Inode 18087941, i_blocks is 717448, should be 717456. Fix? yes
Inode 18087942, i_blocks is 717360, should be 717368. Fix? yes
Inode 18087943, i_blocks is 717112, should be 717120. Fix? yes
Inode 18087944, i_blocks is 717416, should be 717424. Fix? yes
Inode 18087945, i_blocks is 717168, should be 717176. Fix? yes
Inode 18087946, i_blocks is 717608, should be 717616. Fix? yes
Inode 18087947, i_blocks is 717696, should be 717704. Fix? yes
Inode 18087948, i_blocks is 717568, should be 717576. Fix? yes
Inode 18087949, i_blocks is 717488, should be 717496. Fix? yes
Inode 18087950, i_blocks is 717296, should be 717304. Fix? yes
Inode 18087951, i_blocks is 717024, should be 717032. Fix? yes
Inode 18087952, i_blocks is 717176, should be 717184. Fix? yes
Inode 18087953, i_blocks is 717536, should be 717544. Fix? yes
Inode 18087954, i_blocks is 717440, should be 717448. Fix? yes
Inode 18087955, i_blocks is 717472, should be 717480. Fix? yes
Inode 18087956, i_blocks is 717424, should be 717432. Fix? yes
Inode 18087957, i_blocks is 717664, should be 717672. Fix? yes
Inode 18087958, i_blocks is 717616, should be 717624. Fix? yes
Inode 18087959, i_blocks is 717592, should be 717600. Fix? yes
Inode 18087960, i_blocks is 717592, should be 717600. Fix? yes
Inode 18087961, i_blocks is 717616, should be 717624. Fix? yes
Inode 18087962, i_blocks is 716624, should be 716632. Fix? yes
Inode 18087963, i_blocks is 717544, should be 717552. Fix? yes
Inode 18251779, i_blocks is 715136, should be 715144. Fix? yes
Inode 18251780, i_blocks is 715112, should be 715120. Fix? yes
Inode 18251781, i_blocks is 715112, should be 715120. Fix? yes
Inode 18251782, i_blocks is 715120, should be 715128. Fix? yes
Inode 18251783, i_blocks is 719056, should be 719064. Fix? yes
Inode 18251784, i_blocks is 715160, should be 715168. Fix? yes
Inode 18251785, i_blocks is 709984, should be 709992. Fix? yes
Inode 18251786, i_blocks is 715184, should be 715192. Fix? yes
Inode 18251787, i_blocks is 710048, should be 710056. Fix? yes
Inode 18251788, i_blocks is 709904, should be 709912. Fix? yes
Inode 18251789, i_blocks is 718096, should be 718104. Fix? yes
Inode 18251790, i_blocks is 718080, should be 718088. Fix? yes
Inode 18251791, i_blocks is 718088, should be 718096. Fix? yes
Inode 18251792, i_blocks is 718088, should be 718096. Fix? yes
Inode 18251793, i_blocks is 715160, should be 715168. Fix? yes
Inode 18251794, i_blocks is 715136, should be 715144. Fix? yes
Inode 18251795, i_blocks is 715064, should be 715072. Fix? yes
Inode 18251796, i_blocks is 715120, should be 715128. Fix? yes
Inode 18251797, i_blocks is 718080, should be 718088. Fix? yes
Inode 18251798, i_blocks is 718072, should be 718080. Fix? yes
Inode 18251799, i_blocks is 718072, should be 718080. Fix? yes
Inode 18251800, i_blocks is 717992, should be 718000. Fix? yes
Inode 18251801, i_blocks is 714776, should be 714784. Fix? yes
Inode 18251802, i_blocks is 715192, should be 715200. Fix? yes
Inode 18415631, i_blocks is 705168, should be 705176. Fix? yes
Inode 18415633, i_blocks is 640832, should be 640840. Fix? yes
Inode 18481214, i_blocks is 716792, should be 716800. Fix? yes
Inode 18481215, i_blocks is 716792, should be 716800. Fix? yes
Inode 18481216, i_blocks is 714832, should be 714840. Fix? yes
Inode 18481217, i_blocks is 716824, should be 716832. Fix? yes
Inode 18481218, i_blocks is 716816, should be 716824. Fix? yes
Inode 18481219, i_blocks is 716624, should be 716632. Fix? yes
Inode 18481220, i_blocks is 716576, should be 716584. Fix? yes
Inode 18481221, i_blocks is 716816, should be 716824. Fix? yes
Inode 18481222, i_blocks is 716800, should be 716808. Fix? yes
Inode 18481223, i_blocks is 716536, should be 716544. Fix? yes
Inode 18481224, i_blocks is 716792, should be 716800. Fix? yes
Inode 18481225, i_blocks is 716808, should be 716816. Fix? yes
Inode 18481226, i_blocks is 716824, should be 716832. Fix? yes
Inode 18481227, i_blocks is 716848, should be 716856. Fix? yes
Inode 18481228, i_blocks is 716824, should be 716832. Fix? yes
Inode 18481229, i_blocks is 716824, should be 716832. Fix? yes
Inode 18481230, i_blocks is 716824, should be 716832. Fix? yes
Inode 18481231, i_blocks is 716832, should be 716840. Fix? yes
Inode 18481232, i_blocks is 716824, should be 716832. Fix? yes
Inode 18481233, i_blocks is 716792, should be 716800. Fix? yes
Inode 18481234, i_blocks is 716808, should be 716816. Fix? yes
Inode 18481235, i_blocks is 716816, should be 716824. Fix? yes
Inode 18481236, i_blocks is 716808, should be 716816. Fix? yes
Inode 18481237, i_blocks is 716808, should be 716816. Fix? yes
Inode 18644994, i_blocks is 716808, should be 716816. Fix? yes
Inode 18644995, i_blocks is 716816, should be 716824. Fix? yes
Inode 18644996, i_blocks is 716784, should be 716792. Fix? yes
Inode 18644997, i_blocks is 716816, should be 716824. Fix? yes
Inode 18644998, i_blocks is 716792, should be 716800. Fix? yes
Inode 18644999, i_blocks is 716792, should be 716800. Fix? yes
Inode 18645000, i_blocks is 716800, should be 716808. Fix? yes
Inode 18645001, i_blocks is 716816, should be 716824. Fix? yes
Inode 18645002, i_blocks is 716832, should be 716840. Fix? yes
Inode 18645003, i_blocks is 716808, should be 716816. Fix? yes
Inode 18645004, i_blocks is 716824, should be 716832. Fix? yes
Inode 18645005, i_blocks is 716792, should be 716800. Fix? yes
Inode 18645006, i_blocks is 716800, should be 716808. Fix? yes
Inode 18645007, i_blocks is 716824, should be 716832. Fix? yes
Inode 18645008, i_blocks is 716792, should be 716800. Fix? yes
Inode 18645009, i_blocks is 716832, should be 716840. Fix? yes
Inode 18645010, i_blocks is 716824, should be 716832. Fix? yes
Inode 18645011, i_blocks is 716824, should be 716832. Fix? yes
Inode 18645012, i_blocks is 716824, should be 716832. Fix? yes
Inode 18645013, i_blocks is 716840, should be 716848. Fix? yes
Inode 18645014, i_blocks is 716800, should be 716808. Fix? yes
Inode 18645015, i_blocks is 716816, should be 716824. Fix? yes
Inode 18645016, i_blocks is 716808, should be 716816. Fix? yes
Inode 18645017, i_blocks is 716816, should be 716824. Fix? yes
Inode 18645018, i_blocks is 716808, should be 716816. Fix? yes
Inode 18645019, i_blocks is 716816, should be 716824. Fix? yes
Inode 18808834, i_blocks is 716808, should be 716816. Fix? yes
Inode 18808835, i_blocks is 716800, should be 716808. Fix? yes
Inode 18808836, i_blocks is 716816, should be 716824. Fix? yes
Inode 18808837, i_blocks is 716776, should be 716784. Fix? yes
Inode 18808838, i_blocks is 716784, should be 716792. Fix? yes
Inode 18808839, i_blocks is 716808, should be 716816. Fix? yes
Inode 18808840, i_blocks is 717496, should be 717504. Fix? yes
Inode 18808841, i_blocks is 716824, should be 716832. Fix? yes
Inode 18808842, i_blocks is 716808, should be 716816. Fix? yes
Inode 18808843, i_blocks is 716760, should be 716768. Fix? yes
Inode 18808844, i_blocks is 716808, should be 716816. Fix? yes
Inode 18808845, i_blocks is 716792, should be 716800. Fix? yes
Inode 18808846, i_blocks is 716816, should be 716824. Fix? yes
Inode 18808847, i_blocks is 716792, should be 716800. Fix? yes
Inode 18808848, i_blocks is 716832, should be 716840. Fix? yes
Inode 18808849, i_blocks is 716792, should be 716800. Fix? yes
Inode 18808850, i_blocks is 716784, should be 716792. Fix? yes
Inode 18808851, i_blocks is 716744, should be 716752. Fix? yes
Inode 18808852, i_blocks is 716800, should be 716808. Fix? yes
Inode 18808853, i_blocks is 716800, should be 716808. Fix? yes
Inode 18808854, i_blocks is 716776, should be 716784. Fix? yes
Inode 18808855, i_blocks is 716752, should be 716760. Fix? yes
Inode 18808856, i_blocks is 716800, should be 716808. Fix? yes
Inode 18808857, i_blocks is 716776, should be 716784. Fix? yes
Inode 18808858, i_blocks is 716768, should be 716776. Fix? yes
Inode 18808859, i_blocks is 716776, should be 716784. Fix? yes
Inode 18939906, i_blocks is 716808, should be 716816. Fix? yes
Inode 18939907, i_blocks is 716824, should be 716832. Fix? yes
Inode 18939908, i_blocks is 716776, should be 716784. Fix? yes
Inode 18939909, i_blocks is 716784, should be 716792. Fix? yes
Inode 18939910, i_blocks is 716792, should be 716800. Fix? yes
Inode 18939911, i_blocks is 716832, should be 716840. Fix? yes
Inode 18939912, i_blocks is 716800, should be 716808. Fix? yes
Inode 18939913, i_blocks is 716808, should be 716816. Fix? yes
Inode 18939914, i_blocks is 716800, should be 716808. Fix? yes
Inode 18939915, i_blocks is 716656, should be 716664. Fix? yes
Inode 18939916, i_blocks is 716776, should be 716784. Fix? yes
Inode 18939917, i_blocks is 716776, should be 716784. Fix? yes
Inode 18939918, i_blocks is 716768, should be 716776. Fix? yes
Inode 18939919, i_blocks is 716776, should be 716784. Fix? yes
Inode 18939920, i_blocks is 716784, should be 716792. Fix? yes
Inode 18939921, i_blocks is 716768, should be 716776. Fix? yes
Inode 18939922, i_blocks is 716792, should be 716800. Fix? yes
Inode 18939923, i_blocks is 716816, should be 716824. Fix? yes
Inode 18939924, i_blocks is 716808, should be 716816. Fix? yes
Inode 18939925, i_blocks is 716808, should be 716816. Fix? yes
Inode 18939926, i_blocks is 716792, should be 716800. Fix? yes
Inode 18939927, i_blocks is 716808, should be 716816. Fix? yes
Inode 18939928, i_blocks is 716776, should be 716784. Fix? yes
Inode 18939929, i_blocks is 716832, should be 716840. Fix? yes
Inode 18939930, i_blocks is 716800, should be 716808. Fix? yes
Inode 18939931, i_blocks is 716808, should be 716816. Fix? yes
Inode 19103746, i_blocks is 716784, should be 716792. Fix? yes
Inode 19103747, i_blocks is 716768, should be 716776. Fix? yes
Inode 19103748, i_blocks is 716760, should be 716768. Fix? yes
Inode 19103749, i_blocks is 716800, should be 716808. Fix? yes
Inode 19103750, i_blocks is 716792, should be 716800. Fix? yes
Inode 19103751, i_blocks is 716792, should be 716800. Fix? yes
Inode 19103752, i_blocks is 716768, should be 716776. Fix? yes
Inode 19103753, i_blocks is 716784, should be 716792. Fix? yes
Inode 19103754, i_blocks is 716816, should be 716824. Fix? yes
Inode 19103755, i_blocks is 716808, should be 716816. Fix? yes
Inode 19103756, i_blocks is 716824, should be 716832. Fix? yes
Inode 19103757, i_blocks is 716792, should be 716800. Fix? yes
Inode 19103758, i_blocks is 716808, should be 716816. Fix? yes
Inode 19103759, i_blocks is 716776, should be 716784. Fix? yes
Inode 19103760, i_blocks is 716752, should be 716760. Fix? yes
Inode 19103761, i_blocks is 716800, should be 716808. Fix? yes
Inode 19103762, i_blocks is 716792, should be 716800. Fix? yes
Inode 19103763, i_blocks is 716784, should be 716792. Fix? yes
Inode 19103764, i_blocks is 716784, should be 716792. Fix? yes
Inode 19103765, i_blocks is 716792, should be 716800. Fix? yes
Inode 19103766, i_blocks is 716760, should be 716768. Fix? yes
Inode 19103767, i_blocks is 716784, should be 716792. Fix? yes
Inode 19103768, i_blocks is 716736, should be 716744. Fix? yes
Inode 19103769, i_blocks is 716816, should be 716824. Fix? yes
Inode 19103770, i_blocks is 716784, should be 716792. Fix? yes
Inode 19103771, i_blocks is 716816, should be 716824. Fix? yes
Inode 19267586, i_blocks is 716800, should be 716808. Fix? yes
Inode 19267587, i_blocks is 716768, should be 716776. Fix? yes
Inode 19267588, i_blocks is 716784, should be 716792. Fix? yes
Inode 19267589, i_blocks is 716784, should be 716792. Fix? yes
Inode 19267590, i_blocks is 716784, should be 716792. Fix? yes
Inode 19267591, i_blocks is 716776, should be 716784. Fix? yes
Inode 19267592, i_blocks is 716768, should be 716776. Fix? yes
Inode 19267593, i_blocks is 716752, should be 716760. Fix? yes
Inode 19267594, i_blocks is 716776, should be 716784. Fix? yes
Inode 19267595, i_blocks is 716792, should be 716800. Fix? yes
Inode 19267596, i_blocks is 716760, should be 716768. Fix? yes
Inode 19267597, i_blocks is 716792, should be 716800. Fix? yes
Inode 19267598, i_blocks is 716800, should be 716808. Fix? yes
Inode 19267599, i_blocks is 716776, should be 716784. Fix? yes
Inode 19267600, i_blocks is 716736, should be 716744. Fix? yes
Inode 19267601, i_blocks is 716800, should be 716808. Fix? yes
Inode 19267602, i_blocks is 716800, should be 716808. Fix? yes
Inode 19267603, i_blocks is 716800, should be 716808. Fix? yes
Inode 19267604, i_blocks is 716776, should be 716784. Fix? yes
Inode 19267605, i_blocks is 716784, should be 716792. Fix? yes
Inode 19267606, i_blocks is 716824, should be 716832. Fix? yes
Inode 19267607, i_blocks is 716752, should be 716760. Fix? yes
Inode 19398659, i_blocks is 716808, should be 716816. Fix? yes
Inode 19398660, i_blocks is 716792, should be 716800. Fix? yes
Inode 19398661, i_blocks is 716808, should be 716816. Fix? yes
Inode 19398662, i_blocks is 716800, should be 716808. Fix? yes
Inode 19398663, i_blocks is 716800, should be 716808. Fix? yes
Inode 19398664, i_blocks is 716800, should be 716808. Fix? yes
Inode 19398665, i_blocks is 716800, should be 716808. Fix? yes
Inode 19398666, i_blocks is 716800, should be 716808. Fix? yes
Inode 19398667, i_blocks is 716792, should be 716800. Fix? yes
Inode 19398668, i_blocks is 716784, should be 716792. Fix? yes
Inode 19398669, i_blocks is 716776, should be 716784. Fix? yes
Inode 19398670, i_blocks is 716800, should be 716808. Fix? yes
Inode 19398671, i_blocks is 716768, should be 716776. Fix? yes
Inode 19398672, i_blocks is 716808, should be 716816. Fix? yes
Inode 19398673, i_blocks is 716776, should be 716784. Fix? yes
Inode 19398674, i_blocks is 716792, should be 716800. Fix? yes
Inode 19398675, i_blocks is 716648, should be 716656. Fix? yes
Inode 19398676, i_blocks is 716360, should be 716368. Fix? yes
Inode 19398677, i_blocks is 716032, should be 716040. Fix? yes
Inode 19398678, i_blocks is 716728, should be 716736. Fix? yes
Inode 19398679, i_blocks is 716752, should be 716760. Fix? yes
Inode 19398680, i_blocks is 716168, should be 716176. Fix? yes
Inode 19398681, i_blocks is 716760, should be 716768. Fix? yes
Inode 19398682, i_blocks is 716760, should be 716768. Fix? yes
Inode 19628042, i_blocks is 707568, should be 707576. Fix? yes
Inode 19628043, i_blocks is 707816, should be 707824. Fix? yes
Inode 19628044, i_blocks is 689720, should be 689728. Fix? yes
Inode 19628045, i_blocks is 712488, should be 712496. Fix? yes
Inode 19628046, i_blocks is 707512, should be 707520. Fix? yes
Inode 19628047, i_blocks is 707688, should be 707696. Fix? yes
Inode 19628048, i_blocks is 707448, should be 707456. Fix? yes
Inode 19628049, i_blocks is 707472, should be 707480. Fix? yes
Inode 19628050, i_blocks is 709312, should be 709320. Fix? yes
Inode 19628051, i_blocks is 708760, should be 708768. Fix? yes
Inode 19628052, i_blocks is 679152, should be 679160. Fix? yes
Inode 19628053, i_blocks is 702432, should be 702440. Fix? yes
Inode 19628054, i_blocks is 707704, should be 707712. Fix? yes
Inode 19628055, i_blocks is 698648, should be 698656. Fix? yes
Inode 19628056, i_blocks is 708512, should be 708520. Fix? yes
Inode 19628057, i_blocks is 709000, should be 709008. Fix? yes
Inode 19628058, i_blocks is 707720, should be 707728. Fix? yes
Inode 19628059, i_blocks is 707512, should be 707520. Fix? yes
Inode 19628060, i_blocks is 707656, should be 707664. Fix? yes
Inode 19628061, i_blocks is 707744, should be 707752. Fix? yes
Inode 19628062, i_blocks is 702864, should be 702872. Fix? yes
Inode 19628063, i_blocks is 707824, should be 707832. Fix? yes
Inode 19628064, i_blocks is 707768, should be 707776. Fix? yes
Inode 19628065, i_blocks is 707808, should be 707816. Fix? yes
Inode 19791989, i_blocks is 716600, should be 716608. Fix? yes
Inode 19791990, i_blocks is 717376, should be 717384. Fix? yes
Inode 19791991, i_blocks is 716304, should be 716312. Fix? yes
Inode 19791992, i_blocks is 716176, should be 716184. Fix? yes
Inode 19791993, i_blocks is 716272, should be 716280. Fix? yes
Inode 19791994, i_blocks is 718504, should be 718512. Fix? yes
Inode 19791995, i_blocks is 718136, should be 718144. Fix? yes
Inode 19791996, i_blocks is 716632, should be 716640. Fix? yes
Inode 19791997, i_blocks is 717768, should be 717776. Fix? yes
Inode 19791998, i_blocks is 716616, should be 716624. Fix? yes
Inode 19791999, i_blocks is 716992, should be 717000. Fix? yes
Inode 19792000, i_blocks is 718456, should be 718464. Fix? yes
Inode 19792001, i_blocks is 718680, should be 718688. Fix? yes
Inode 19792002, i_blocks is 717440, should be 717448. Fix? yes
Inode 19792003, i_blocks is 718240, should be 718248. Fix? yes
Inode 19792004, i_blocks is 716472, should be 716480. Fix? yes
Inode 19792005, i_blocks is 718168, should be 718176. Fix? yes
Inode 19792006, i_blocks is 718080, should be 718088. Fix? yes
Inode 19792008, i_blocks is 717640, should be 717648. Fix? yes
Inode 19792009, i_blocks is 718016, should be 718024. Fix? yes
Inode 19792010, i_blocks is 717816, should be 717824. Fix? yes
Inode 19792011, i_blocks is 718032, should be 718040. Fix? yes
Inode 19792012, i_blocks is 717856, should be 717864. Fix? yes
Inode 19792013, i_blocks is 717656, should be 717664. Fix? yes
Inode 19792014, i_blocks is 717336, should be 717344. Fix? yes
Inode 19792015, i_blocks is 717256, should be 717264. Fix? yes
Inode 19792016, i_blocks is 717656, should be 717664. Fix? yes
Inode 19792017, i_blocks is 717248, should be 717256. Fix? yes
Inode 19792018, i_blocks is 717440, should be 717448. Fix? yes
Inode 19792019, i_blocks is 717664, should be 717672. Fix? yes
Inode 19792020, i_blocks is 717656, should be 717664. Fix? yes
Inode 19792021, i_blocks is 717656, should be 717664. Fix? yes
Inode 19792022, i_blocks is 717640, should be 717648. Fix? yes
Inode 19792023, i_blocks is 717656, should be 717664. Fix? yes
Inode 19792024, i_blocks is 717648, should be 717656. Fix? yes
Inode 19792025, i_blocks is 717640, should be 717648. Fix? yes
Inode 19792026, i_blocks is 717160, should be 717168. Fix? yes
Inode 19792027, i_blocks is 717656, should be 717664. Fix? yes
Inode 19792028, i_blocks is 717664, should be 717672. Fix? yes
Inode 19792029, i_blocks is 717656, should be 717664. Fix? yes
Inode 19792030, i_blocks is 717648, should be 717656. Fix? yes
Inode 19792031, i_blocks is 717656, should be 717664. Fix? yes
Inode 19792032, i_blocks is 717656, should be 717664. Fix? yes
Inode 19792033, i_blocks is 717640, should be 717648. Fix? yes
Inode 19792035, i_blocks is 718032, should be 718040. Fix? yes
Inode 19792036, i_blocks is 717240, should be 717248. Fix? yes
Inode 19792037, i_blocks is 717816, should be 717824. Fix? yes
Inode 19792038, i_blocks is 717432, should be 717440. Fix? yes
Inode 19792039, i_blocks is 717656, should be 717664. Fix? yes
Inode 19792040, i_blocks is 717456, should be 717464. Fix? yes
Inode 19792041, i_blocks is 717656, should be 717664. Fix? yes
Inode 19792042, i_blocks is 717760, should be 717768. Fix? yes
Inode 19792043, i_blocks is 717248, should be 717256. Fix? yes
Inode 19792044, i_blocks is 717872, should be 717880. Fix? yes
Inode 19792045, i_blocks is 717664, should be 717672. Fix? yes
Inode 19792046, i_blocks is 717456, should be 717464. Fix? yes
Inode 19792047, i_blocks is 718232, should be 718240. Fix? yes
Inode 19792048, i_blocks is 717640, should be 717648. Fix? yes
Inode 19792049, i_blocks is 717840, should be 717848. Fix? yes
Inode 19792050, i_blocks is 717648, should be 717656. Fix? yes
Inode 19792051, i_blocks is 717240, should be 717248. Fix? yes
Inode 19792052, i_blocks is 718056, should be 718064. Fix? yes
Inode 19792053, i_blocks is 717648, should be 717656. Fix? yes
Inode 19792054, i_blocks is 717232, should be 717240. Fix? yes
Inode 19792055, i_blocks is 717056, should be 717064. Fix? yes
Inode 19792056, i_blocks is 717648, should be 717656. Fix? yes
Inode 19792057, i_blocks is 717248, should be 717256. Fix? yes
Inode 19792058, i_blocks is 717632, should be 717640. Fix? yes
Inode 19792059, i_blocks is 718056, should be 718064. Fix? yes
Inode 19792060, i_blocks is 717648, should be 717656. Fix? yes
Inode 19792063, i_blocks is 717608, should be 717616. Fix? yes
Inode 19792064, i_blocks is 717240, should be 717248. Fix? yes
Inode 19792065, i_blocks is 717616, should be 717624. Fix? yes
Inode 19792066, i_blocks is 717640, should be 717648. Fix? yes
Inode 19792067, i_blocks is 717632, should be 717640. Fix? yes
Inode 19792068, i_blocks is 718624, should be 718632. Fix? yes
Inode 19792069, i_blocks is 717280, should be 717288. Fix? yes
Inode 19792070, i_blocks is 719216, should be 719224. Fix? yes
Inode 19792071, i_blocks is 719408, should be 719416. Fix? yes
Inode 19792072, i_blocks is 718832, should be 718840. Fix? yes
Inode 19792073, i_blocks is 717240, should be 717248. Fix? yes
Inode 19792074, i_blocks is 717432, should be 717440. Fix? yes
Inode 19792075, i_blocks is 717240, should be 717248. Fix? yes
Inode 19792076, i_blocks is 719024, should be 719032. Fix? yes
Inode 19792077, i_blocks is 711104, should be 711112. Fix? yes
Inode 19792078, i_blocks is 715304, should be 715312. Fix? yes
Inode 19792079, i_blocks is 718040, should be 718048. Fix? yes
Inode 19792080, i_blocks is 717240, should be 717248. Fix? yes
Inode 19792081, i_blocks is 713440, should be 713448. Fix? yes
Inode 19792082, i_blocks is 717816, should be 717824. Fix? yes
Inode 19792083, i_blocks is 716976, should be 716984. Fix? yes
Inode 19792084, i_blocks is 715360, should be 715368. Fix? yes
Inode 19792085, i_blocks is 719016, should be 719024. Fix? yes
Inode 19792086, i_blocks is 718632, should be 718640. Fix? yes
Inode 19792088, i_blocks is 716872, should be 716880. Fix? yes
Inode 19792089, i_blocks is 717576, should be 717584. Fix? yes
Inode 19792090, i_blocks is 709800, should be 709808. Fix? yes
Inode 19792091, i_blocks is 707760, should be 707768. Fix? yes
Inode 19792092, i_blocks is 709840, should be 709848. Fix? yes
Inode 19792093, i_blocks is 710104, should be 710112. Fix? yes
Inode 19792094, i_blocks is 710008, should be 710016. Fix? yes
Inode 19792095, i_blocks is 717048, should be 717056. Fix? yes
Inode 19792096, i_blocks is 707536, should be 707544. Fix? yes
Inode 19792097, i_blocks is 707520, should be 707528. Fix? yes
Inode 19792098, i_blocks is 706872, should be 706880. Fix? yes
Inode 19792099, i_blocks is 707704, should be 707712. Fix? yes
Inode 19792100, i_blocks is 711432, should be 711440. Fix? yes
Inode 19792101, i_blocks is 711344, should be 711352. Fix? yes
Inode 19792102, i_blocks is 711360, should be 711368. Fix? yes
Inode 19792103, i_blocks is 710224, should be 710232. Fix? yes
Inode 19792104, i_blocks is 716840, should be 716848. Fix? yes
Inode 19792105, i_blocks is 711928, should be 711936. Fix? yes
Inode 19792106, i_blocks is 676584, should be 676592. Fix? yes
Inode 19792107, i_blocks is 709976, should be 709984. Fix? yes
Inode 19792108, i_blocks is 647272, should be 647280. Fix? yes
Inode 19792109, i_blocks is 711864, should be 711872. Fix? yes
Inode 19792110, i_blocks is 709224, should be 709232. Fix? yes
Inode 19792111, i_blocks is 710032, should be 710040. Fix? yes
Inode 19792112, i_blocks is 707472, should be 707480. Fix? yes
Inode 19792113, i_blocks is 708008, should be 708016. Fix? yes
Inode 19792115, i_blocks is 717000, should be 717008. Fix? yes
Inode 19792116, i_blocks is 716968, should be 716976. Fix? yes
Inode 19792117, i_blocks is 717016, should be 717024. Fix? yes
Inode 19792118, i_blocks is 717024, should be 717032. Fix? yes
Inode 19792119, i_blocks is 716968, should be 716976. Fix? yes
Inode 19792120, i_blocks is 716968, should be 716976. Fix? yes
Inode 19792121, i_blocks is 716960, should be 716968. Fix? yes
Inode 19792122, i_blocks is 717000, should be 717008. Fix? yes
Inode 19792123, i_blocks is 717008, should be 717016. Fix? yes
Inode 19792124, i_blocks is 716968, should be 716976. Fix? yes
Inode 19792125, i_blocks is 717000, should be 717008. Fix? yes
Inode 19792126, i_blocks is 717008, should be 717016. Fix? yes
Inode 19792127, i_blocks is 716992, should be 717000. Fix? yes
Inode 19792128, i_blocks is 716936, should be 716944. Fix? yes
Inode 19792129, i_blocks is 717000, should be 717008. Fix? yes
Inode 19792130, i_blocks is 717000, should be 717008. Fix? yes
Inode 19792131, i_blocks is 716944, should be 716952. Fix? yes
Inode 19792132, i_blocks is 716976, should be 716984. Fix? yes
Inode 19792133, i_blocks is 717000, should be 717008. Fix? yes
Inode 19792134, i_blocks is 716992, should be 717000. Fix? yes
Inode 19792135, i_blocks is 717000, should be 717008. Fix? yes
Inode 19792136, i_blocks is 716968, should be 716976. Fix? yes
Inode 19792137, i_blocks is 716992, should be 717000. Fix? yes
Inode 19792138, i_blocks is 716992, should be 717000. Fix? yes
Inode 19792139, i_blocks is 716984, should be 716992. Fix? yes
Inode 19792140, i_blocks is 717000, should be 717008. Fix? yes
Inode 19792147, i_blocks is 775408, should be 775416. Fix? yes
Inode 19792149, i_blocks is 715640, should be 715648. Fix? yes
Inode 19792150, i_blocks is 715968, should be 715976. Fix? yes
Inode 19792151, i_blocks is 715680, should be 715688. Fix? yes
Inode 19792152, i_blocks is 715656, should be 715664. Fix? yes
Inode 19792153, i_blocks is 716408, should be 716416. Fix? yes
Inode 19792154, i_blocks is 716168, should be 716176. Fix? yes
Inode 19792155, i_blocks is 715832, should be 715840. Fix? yes
Inode 19792156, i_blocks is 715896, should be 715904. Fix? yes
Inode 19792157, i_blocks is 715992, should be 716000. Fix? yes
Inode 19792158, i_blocks is 716768, should be 716776. Fix? yes
Inode 19792159, i_blocks is 712528, should be 712536. Fix? yes
Inode 19792160, i_blocks is 714968, should be 714976. Fix? yes
Inode 19792163, i_blocks is 712208, should be 712216. Fix? yes
Inode 19792164, i_blocks is 715416, should be 715424. Fix? yes
Inode 19792165, i_blocks is 715912, should be 715920. Fix? yes
Inode 19792166, i_blocks is 715224, should be 715232. Fix? yes
Inode 19792167, i_blocks is 715784, should be 715792. Fix? yes
Inode 19792168, i_blocks is 717968, should be 717976. Fix? yes
Inode 19792169, i_blocks is 717224, should be 717232. Fix? yes
Inode 19792170, i_blocks is 717416, should be 717424. Fix? yes
Inode 19792171, i_blocks is 716808, should be 716816. Fix? yes
Inode 19792172, i_blocks is 716128, should be 716136. Fix? yes
Inode 19792173, i_blocks is 715816, should be 715824. Fix? yes
Inode 19792174, i_blocks is 716104, should be 716112. Fix? yes
Inode 19792175, i_blocks is 715144, should be 715152. Fix? yes
Inode 19792178, i_blocks is 716584, should be 716592. Fix? yes
Inode 19792179, i_blocks is 716208, should be 716216. Fix? yes
Inode 19792180, i_blocks is 716000, should be 716008. Fix? yes
Inode 19792181, i_blocks is 717112, should be 717120. Fix? yes
Inode 19792182, i_blocks is 715848, should be 715856. Fix? yes
Inode 19792183, i_blocks is 717448, should be 717456. Fix? yes
Inode 19792184, i_blocks is 715560, should be 715568. Fix? yes
Inode 19792185, i_blocks is 715616, should be 715624. Fix? yes
Inode 19792186, i_blocks is 715904, should be 715912. Fix? yes
Inode 19792187, i_blocks is 716208, should be 716216. Fix? yes
Inode 19792188, i_blocks is 715360, should be 715368. Fix? yes
Inode 19792189, i_blocks is 715816, should be 715824. Fix? yes
Inode 19792190, i_blocks is 716024, should be 716032. Fix? yes
Inode 19792192, i_blocks is 716944, should be 716952. Fix? yes
Inode 19792193, i_blocks is 717984, should be 717992. Fix? yes
Inode 19792194, i_blocks is 720240, should be 720248. Fix? yes
Inode 19792195, i_blocks is 717448, should be 717456. Fix? yes
Inode 19792196, i_blocks is 717168, should be 717176. Fix? yes
Inode 19792197, i_blocks is 718808, should be 718816. Fix? yes
Inode 19792198, i_blocks is 717120, should be 717128. Fix? yes
Inode 19792199, i_blocks is 716832, should be 716840. Fix? yes
Inode 19792200, i_blocks is 713776, should be 713784. Fix? yes
Inode 19792201, i_blocks is 718624, should be 718632. Fix? yes
Inode 19792202, i_blocks is 716728, should be 716736. Fix? yes
Inode 19792203, i_blocks is 716720, should be 716728. Fix? yes
Inode 19792204, i_blocks is 716936, should be 716944. Fix? yes
Inode 19792208, i_blocks is 717560, should be 717568. Fix? yes
Inode 19792209, i_blocks is 717632, should be 717640. Fix? yes
Inode 19792210, i_blocks is 717704, should be 717712. Fix? yes
Inode 19792211, i_blocks is 712000, should be 712008. Fix? yes
Inode 19792212, i_blocks is 717784, should be 717792. Fix? yes
Inode 19792213, i_blocks is 711816, should be 711824. Fix? yes
Inode 19792214, i_blocks is 717304, should be 717312. Fix? yes
Inode 19792215, i_blocks is 717704, should be 717712. Fix? yes
Inode 19792216, i_blocks is 717048, should be 717056. Fix? yes
Inode 19792217, i_blocks is 714256, should be 714264. Fix? yes
Inode 19792218, i_blocks is 712352, should be 712360. Fix? yes
Inode 19792228, i_blocks is 717144, should be 717152. Fix? yes
Inode 19792229, i_blocks is 717080, should be 717088. Fix? yes
Inode 19792230, i_blocks is 717104, should be 717112. Fix? yes
Inode 19792231, i_blocks is 717128, should be 717136. Fix? yes
Inode 19792232, i_blocks is 717144, should be 717152. Fix? yes
Inode 19792233, i_blocks is 717168, should be 717176. Fix? yes
Inode 19792234, i_blocks is 717136, should be 717144. Fix? yes
Inode 19792235, i_blocks is 717136, should be 717144. Fix? yes
Inode 19792237, i_blocks is 717152, should be 717160. Fix? yes
Inode 19792238, i_blocks is 715368, should be 715376. Fix? yes
Inode 19792239, i_blocks is 717128, should be 717136. Fix? yes
Inode 19792240, i_blocks is 717144, should be 717152. Fix? yes
Inode 19792241, i_blocks is 716920, should be 716928. Fix? yes
Inode 19792242, i_blocks is 717112, should be 717120. Fix? yes
Inode 19792243, i_blocks is 715136, should be 715144. Fix? yes
Inode 19792244, i_blocks is 717128, should be 717136. Fix? yes
Inode 19792245, i_blocks is 717120, should be 717128. Fix? yes
Inode 19792246, i_blocks is 717144, should be 717152. Fix? yes
Inode 19792247, i_blocks is 717120, should be 717128. Fix? yes
Inode 19792248, i_blocks is 717080, should be 717088. Fix? yes
Inode 19792249, i_blocks is 717144, should be 717152. Fix? yes
Inode 19792250, i_blocks is 717144, should be 717152. Fix? yes
Inode 19792278, i_blocks is 717064, should be 717072. Fix? yes
Inode 19792279, i_blocks is 717120, should be 717128. Fix? yes
Inode 19792280, i_blocks is 717160, should be 717168. Fix? yes
Inode 19792281, i_blocks is 717168, should be 717176. Fix? yes
Inode 19792282, i_blocks is 717168, should be 717176. Fix? yes
Inode 19792283, i_blocks is 717160, should be 717168. Fix? yes
Inode 19792284, i_blocks is 717112, should be 717120. Fix? yes
Inode 19792285, i_blocks is 717088, should be 717096. Fix? yes
Inode 19792286, i_blocks is 717120, should be 717128. Fix? yes
Inode 19792287, i_blocks is 717112, should be 717120. Fix? yes
Inode 19792288, i_blocks is 717168, should be 717176. Fix? yes
Inode 19792289, i_blocks is 717112, should be 717120. Fix? yes
Inode 19792290, i_blocks is 717112, should be 717120. Fix? yes
Inode 19792291, i_blocks is 717168, should be 717176. Fix? yes
Inode 19792292, i_blocks is 717040, should be 717048. Fix? yes
Inode 19792293, i_blocks is 717152, should be 717160. Fix? yes
Inode 19792294, i_blocks is 717176, should be 717184. Fix? yes
Inode 19792295, i_blocks is 717136, should be 717144. Fix? yes
Inode 19792296, i_blocks is 717128, should be 717136. Fix? yes
Inode 19792297, i_blocks is 717152, should be 717160. Fix? yes
Inode 19792298, i_blocks is 717120, should be 717128. Fix? yes
Inode 19792299, i_blocks is 717104, should be 717112. Fix? yes
Inode 19792300, i_blocks is 717160, should be 717168. Fix? yes
Inode 19792301, i_blocks is 717120, should be 717128. Fix? yes
Inode 19792302, i_blocks is 717136, should be 717144. Fix? yes
Inode 19792303, i_blocks is 717160, should be 717168. Fix? yes
Inode 19792332, i_blocks is 717056, should be 717064. Fix? yes
Inode 19792333, i_blocks is 717040, should be 717048. Fix? yes
Inode 19792334, i_blocks is 717120, should be 717128. Fix? yes
Inode 19792335, i_blocks is 717168, should be 717176. Fix? yes
Inode 19792336, i_blocks is 717200, should be 717208. Fix? yes
Inode 19792337, i_blocks is 717168, should be 717176. Fix? yes
Inode 19792338, i_blocks is 717192, should be 717200. Fix? yes
Inode 19792339, i_blocks is 717208, should be 717216. Fix? yes
Inode 19792340, i_blocks is 717112, should be 717120. Fix? yes
Inode 19792341, i_blocks is 717136, should be 717144. Fix? yes
Inode 19792342, i_blocks is 717168, should be 717176. Fix? yes
Inode 19792343, i_blocks is 717168, should be 717176. Fix? yes
Inode 19792344, i_blocks is 717168, should be 717176. Fix? yes
Inode 19792345, i_blocks is 717128, should be 717136. Fix? yes
Inode 19792347, i_blocks is 717136, should be 717144. Fix? yes
Inode 19792348, i_blocks is 717136, should be 717144. Fix? yes
Inode 19792349, i_blocks is 717176, should be 717184. Fix? yes
Inode 19792350, i_blocks is 717128, should be 717136. Fix? yes
Inode 19792351, i_blocks is 717152, should be 717160. Fix? yes
Inode 19792352, i_blocks is 717152, should be 717160. Fix? yes
Inode 19792353, i_blocks is 717136, should be 717144. Fix? yes
Inode 19792354, i_blocks is 717136, should be 717144. Fix? yes
Inode 19792355, i_blocks is 717152, should be 717160. Fix? yes
Inode 19792356, i_blocks is 717144, should be 717152. Fix? yes
Inode 19792384, i_blocks is 717184, should be 717192. Fix? yes
Inode 19792385, i_blocks is 717176, should be 717184. Fix? yes
Inode 19792386, i_blocks is 717200, should be 717208. Fix? yes
Inode 19792387, i_blocks is 717096, should be 717104. Fix? yes
Inode 19792388, i_blocks is 717192, should be 717200. Fix? yes
Inode 19792389, i_blocks is 717184, should be 717192. Fix? yes
Inode 19792390, i_blocks is 717144, should be 717152. Fix? yes
Inode 19792391, i_blocks is 717192, should be 717200. Fix? yes
Inode 19792392, i_blocks is 717168, should be 717176. Fix? yes
Inode 19792393, i_blocks is 717168, should be 717176. Fix? yes
Inode 19792394, i_blocks is 716904, should be 716912. Fix? yes
Inode 19792395, i_blocks is 717192, should be 717200. Fix? yes
Inode 19792396, i_blocks is 717200, should be 717208. Fix? yes
Inode 19792397, i_blocks is 717168, should be 717176. Fix? yes
Inode 19792398, i_blocks is 717192, should be 717200. Fix? yes
Inode 19792399, i_blocks is 717216, should be 717224. Fix? yes
Inode 19792400, i_blocks is 717176, should be 717184. Fix? yes
Inode 19792401, i_blocks is 717192, should be 717200. Fix? yes
Inode 19792402, i_blocks is 717184, should be 717192. Fix? yes
Inode 19792403, i_blocks is 717192, should be 717200. Fix? yes
Inode 19792404, i_blocks is 717184, should be 717192. Fix? yes
Inode 19792405, i_blocks is 717184, should be 717192. Fix? yes
Inode 19792406, i_blocks is 717160, should be 717168. Fix? yes
Inode 19792407, i_blocks is 717272, should be 717280. Fix? yes
Inode 19792408, i_blocks is 717192, should be 717200. Fix? yes
Inode 19792409, i_blocks is 717184, should be 717192. Fix? yes
Inode 19792438, i_blocks is 712920, should be 712928. Fix? yes
Inode 19792439, i_blocks is 712872, should be 712880. Fix? yes
Inode 19792440, i_blocks is 712864, should be 712872. Fix? yes
Inode 19792441, i_blocks is 712872, should be 712880. Fix? yes
Inode 19792442, i_blocks is 712888, should be 712896. Fix? yes
Inode 19792443, i_blocks is 712880, should be 712888. Fix? yes
Inode 19792444, i_blocks is 712864, should be 712872. Fix? yes
Inode 19792445, i_blocks is 712896, should be 712904. Fix? yes
Inode 19792446, i_blocks is 712928, should be 712936. Fix? yes
Inode 19792447, i_blocks is 712904, should be 712912. Fix? yes
Inode 19792448, i_blocks is 712896, should be 712904. Fix? yes
Inode 19792449, i_blocks is 712864, should be 712872. Fix? yes
Inode 19792450, i_blocks is 712872, should be 712880. Fix? yes
Inode 19792451, i_blocks is 717960, should be 717968. Fix? yes
Inode 19792452, i_blocks is 712864, should be 712872. Fix? yes
Inode 19792453, i_blocks is 712872, should be 712880. Fix? yes
Inode 19792454, i_blocks is 712880, should be 712888. Fix? yes
Inode 19792455, i_blocks is 712880, should be 712888. Fix? yes
Inode 19792456, i_blocks is 712904, should be 712912. Fix? yes
Inode 19792457, i_blocks is 712904, should be 712912. Fix? yes
Inode 19792458, i_blocks is 712912, should be 712920. Fix? yes
Inode 19792459, i_blocks is 712912, should be 712920. Fix? yes
Inode 19792460, i_blocks is 712904, should be 712912. Fix? yes
Inode 19792461, i_blocks is 712872, should be 712880. Fix? yes
Inode 19792462, i_blocks is 712904, should be 712912. Fix? yes
Inode 19792463, i_blocks is 712864, should be 712872. Fix? yes
Inode 19792492, i_blocks is 712888, should be 712896. Fix? yes
Inode 19792493, i_blocks is 712880, should be 712888. Fix? yes
Inode 19792494, i_blocks is 712872, should be 712880. Fix? yes
Inode 19792495, i_blocks is 712888, should be 712896. Fix? yes
Inode 19792496, i_blocks is 712904, should be 712912. Fix? yes
Inode 19792497, i_blocks is 712880, should be 712888. Fix? yes
Inode 19792498, i_blocks is 712896, should be 712904. Fix? yes
Inode 19792499, i_blocks is 712872, should be 712880. Fix? yes
Inode 19792500, i_blocks is 712864, should be 712872. Fix? yes
Inode 19792501, i_blocks is 712880, should be 712888. Fix? yes
Inode 19792502, i_blocks is 712896, should be 712904. Fix? yes
Inode 19792503, i_blocks is 712888, should be 712896. Fix? yes
Inode 19792504, i_blocks is 712880, should be 712888. Fix? yes
Inode 19792505, i_blocks is 712880, should be 712888. Fix? yes
Inode 19792506, i_blocks is 712896, should be 712904. Fix? yes
Inode 19792507, i_blocks is 712880, should be 712888. Fix? yes
Inode 19792508, i_blocks is 712880, should be 712888. Fix? yes
Inode 19792509, i_blocks is 712856, should be 712864. Fix? yes
Inode 19792510, i_blocks is 712872, should be 712880. Fix? yes
Inode 19792511, i_blocks is 712888, should be 712896. Fix? yes
Inode 19792512, i_blocks is 712904, should be 712912. Fix? yes
Inode 19792513, i_blocks is 712872, should be 712880. Fix? yes
Inode 19792514, i_blocks is 540496, should be 540504. Fix? yes
Inode 19792515, i_blocks is 712872, should be 712880. Fix? yes
Inode 19792516, i_blocks is 712856, should be 712864. Fix? yes
Inode 19792517, i_blocks is 712872, should be 712880. Fix? yes
Inode 19792547, i_blocks is 711976, should be 711984. Fix? yes
Inode 19792548, i_blocks is 712000, should be 712008. Fix? yes
Inode 19792549, i_blocks is 711976, should be 711984. Fix? yes
Inode 19792550, i_blocks is 711976, should be 711984. Fix? yes
Inode 19792551, i_blocks is 711968, should be 711976. Fix? yes
Inode 19792552, i_blocks is 711992, should be 712000. Fix? yes
Inode 19792553, i_blocks is 711992, should be 712000. Fix? yes
Inode 19792554, i_blocks is 711984, should be 711992. Fix? yes
Inode 19792555, i_blocks is 711984, should be 711992. Fix? yes
Inode 19792556, i_blocks is 712000, should be 712008. Fix? yes
Inode 19792557, i_blocks is 711984, should be 711992. Fix? yes
Inode 19792558, i_blocks is 711984, should be 711992. Fix? yes
Inode 19792559, i_blocks is 711984, should be 711992. Fix? yes
Inode 19792560, i_blocks is 711992, should be 712000. Fix? yes
Pass 2: Checking directory structure
Pass 3: Checking directory connectivity
Pass 4: Checking reference counts
Pass 5: Checking group summary information
/dev/mapper/c-c: ***** FILE SYSTEM WAS MODIFIED *****
/dev/mapper/c-c: 5064/30285824 files (1.0% non-contiguous), 333499778/484573184 blocks
