GNijhuis
Sep 15, 2015Aspirant
Installation Problem NAS102
Hello, This afternoon i bought a new NAS102 with two WD Red Nas Hard Drives. I tried to setup the NAS but it won't work. The problem is that the NAS can't be found using the Readycloud (http...
GNijhuis
Yes I took another look at the disks and I already closed him before I putted him in the bay.
Thank you!
mdgm-ntgr
Sep 15, 2015NETGEAR Employee Retired
Can you send me a screenshot of what you see in RAIDar?
- GNijhuisSep 16, 2015Aspirant
I'm now a step further in the proces. On Readycloud he sees mine NAS. But now I have to press at 'Manage' and then he tried to connect me to 192.168.1.13 and ask me for an username and a password. I tried to use my login for readycloud but that doesn't work. Also I tried to use 'admin' and 'admin' but that also doesn't work.
Does somebody knows what I have to type there?
- vandermerweSep 16, 2015Master
admin/password are the username and password combination you need for the GUI.
Readycloud is really for remote access to the readynas, are you planning to remotely access your readynas? It's use during the setup process is a little confusing to new users I must say.
For local access, especially to the GUI, I would suggest using Raidar:
http://kb.netgear.com/app/answers/detail/a_id/20684/related/1#raidar
You also have access to the manuals here:
http://support.netgear.com/product/RN10200
