gpaolo
Dec 03, 2020Luminary
Installing Domoticz on OS6 RN524
Hi all, I have just upgraded my home heating system and I would like to install Domoticz on my NAS to monitor what is doing. I have followed the instructions on https://www.jaqb.gda.pl/pol/Spoleczno...
- Dec 11, 2020
I have seen a couple of posts here on the forum from people complaining about these same outdated libraries, so I tried another approach.
I found a website which keeps the old releases of Domoticz: https://domoticaboard.nl/index.php?PHPSESSID=91e63804132fc23afa50b81d16f04790&board=16.0
I have downloaded the latest V4 stable release, installed following the instructions on the website linked on the first post and it worked straight away.
So, until OS6 is updated with the newer linux libraries, it looks like the only way to go is to use the previous version of Domoticz.
I hope it helps other people that might want to try this program.
Sandshark
Dec 03, 2020Sensei
Exit code 127 is "unknown command". I suspect there is a dependancy issue and that the program requires something that's not installed on the NAS. Perhaps there is a "verbose" mode for Domoticz or a method to turn on a debugging log that could give you more help.
gpaolo
I see... ok thanks, I have asked also on their forum, I'll see if I can get some more detail. If I get a solution I'll post it here too in case someone else needs it.
I was a bit surprised that it was not in the applications of the NAS, it seems extremely popular for other brands, but barely nothing for ReadyNAS...
- gpaoloDec 06, 2020Luminary
I'm not sure if it's a progress or not, but I get this error when I try to launch it manually:
./domoticz: error while loading shared libraries: libssl.so.1.1: cannot open shared object file: No such file or directory
so I tried to follow the instructions for the installation on Debian and got this package installed, but I still get the same error:
root@MY_NAS_NAME:/opt/domoticz# apt-get install cmake libssl-dev Reading package lists... Done Building dependency tree Reading state information... Done The following additional packages will be installed: cmake-data zlib1g zlib1g-dev Suggested packages: codeblocks eclipse ninja-build Recommended packages: libssl-doc The following NEW packages will be installed: cmake cmake-data libssl-dev zlib1g-dev The following packages will be upgraded: zlib1g 1 upgraded, 4 newly installed, 0 to remove and 31 not upgraded. Need to get 4,892 kB of archives. After this operation, 23.9 MB of additional disk space will be used. Do you want to continue? [Y/n] Y Get:1 http://security.debian.org jessie/updates/main amd64 zlib1g amd64 1:1.2.8.dfsg-2+deb8u1 [88.3 kB] Get:2 http://security.debian.org jessie/updates/main amd64 zlib1g-dev amd64 1:1.2.8.dfsg-2+deb8u1 [206 kB] Get:3 http://security.debian.org jessie/updates/main amd64 libssl-dev amd64 1.0.1t-1+deb8u12 [1,284 kB] Get:4 http://mirrors.edge.kernel.org/debian jessie/main amd64 cmake-data all 3.0.2-1+deb8u1 [929 kB] Get:5 http://mirrors.edge.kernel.org/debian jessie/main amd64 cmake amd64 3.0.2-1+deb8u1 [2,385 kB] Fetched 4,892 kB in 1s (2,446 kB/s) debconf: delaying package configuration, since apt-utils is not installed (Reading database ... 22825 files and directories currently installed.) Preparing to unpack .../zlib1g_1%3a1.2.8.dfsg-2+deb8u1_amd64.deb ... Unpacking zlib1g:amd64 (1:1.2.8.dfsg-2+deb8u1) over (1:1.2.8.dfsg-2+b1) ... Setting up zlib1g:amd64 (1:1.2.8.dfsg-2+deb8u1) ... Processing triggers for libc-bin (2.19-18+deb8u10.netgear1) ... Selecting previously unselected package cmake-data. (Reading database ... 22824 files and directories currently installed.) Preparing to unpack .../cmake-data_3.0.2-1+deb8u1_all.deb ... Unpacking cmake-data (3.0.2-1+deb8u1) ... Selecting previously unselected package cmake. Preparing to unpack .../cmake_3.0.2-1+deb8u1_amd64.deb ... Unpacking cmake (3.0.2-1+deb8u1) ... Selecting previously unselected package zlib1g-dev:amd64. Preparing to unpack .../zlib1g-dev_1%3a1.2.8.dfsg-2+deb8u1_amd64.deb ... Unpacking zlib1g-dev:amd64 (1:1.2.8.dfsg-2+deb8u1) ... Selecting previously unselected package libssl-dev:amd64. Preparing to unpack .../libssl-dev_1.0.1t-1+deb8u12_amd64.deb ... Unpacking libssl-dev:amd64 (1.0.1t-1+deb8u12) ... Setting up cmake-data (3.0.2-1+deb8u1) ... Setting up cmake (3.0.2-1+deb8u1) ... Setting up zlib1g-dev:amd64 (1:1.2.8.dfsg-2+deb8u1) ... Setting up libssl-dev:amd64 (1.0.1t-1+deb8u12) ... root@MY_NAS_NAME:/opt/domoticz# ./domoticz ./domoticz: error while loading shared libraries: libssl.so.1.1: cannot open shared object file: No such file or directory
Any idea if I'm doing something wrong? I feel really uncomfortable in trying these things as root...
- gpaoloDec 10, 2020Luminary
I'm having problem with a missing package, which requires a more updated version of another package that seems to be coming from Netgear. I'm trying to install libssl1.1 but apparently the libc6 is outdated:
Selecting previously unselected package libssl1.1:amd64. (Reading database ... 24659 files and directories currently installed.) Preparing to unpack libssl1.1_1.1.1d-0+deb10u4_amd64.deb ... Unpacking libssl1.1:amd64 (1.1.1d-0+deb10u4) ... dpkg: dependency problems prevent configuration of libssl1.1:amd64: libssl1.1:amd64 depends on libc6 (>= 2.25); however: Version of libc6:amd64 on system is 2.19-18+deb8u10.netgear1. dpkg: error processing package libssl1.1:amd64 (--install): dependency problems - leaving unconfigured Processing triggers for libc-bin (2.19-18+deb8u10.netgear1) ... Errors were encountered while processing: libssl1.1:amd64
As the actual version has the "netgeat1" name, I guess it's sort of customized? Any thought about this?
- gpaoloDec 11, 2020Luminary
