gpaolo
Dec 03, 2020Luminary
Installing Domoticz on OS6 RN524
Hi all, I have just upgraded my home heating system and I would like to install Domoticz on my NAS to monitor what is doing. I have followed the instructions on https://www.jaqb.gda.pl/pol/Spoleczno...
- Dec 11, 2020
I have seen a couple of posts here on the forum from people complaining about these same outdated libraries, so I tried another approach.
I found a website which keeps the old releases of Domoticz: https://domoticaboard.nl/index.php?PHPSESSID=91e63804132fc23afa50b81d16f04790&board=16.0
I have downloaded the latest V4 stable release, installed following the instructions on the website linked on the first post and it worked straight away.
So, until OS6 is updated with the newer linux libraries, it looks like the only way to go is to use the previous version of Domoticz.
I hope it helps other people that might want to try this program.
gpaolo
Dec 10, 2020Luminary
I'm having problem with a missing package, which requires a more updated version of another package that seems to be coming from Netgear. I'm trying to install libssl1.1 but apparently the libc6 is outdated:
Selecting previously unselected package libssl1.1:amd64. (Reading database ... 24659 files and directories currently installed.) Preparing to unpack libssl1.1_1.1.1d-0+deb10u4_amd64.deb ... Unpacking libssl1.1:amd64 (1.1.1d-0+deb10u4) ... dpkg: dependency problems prevent configuration of libssl1.1:amd64: libssl1.1:amd64 depends on libc6 (>= 2.25); however: Version of libc6:amd64 on system is 2.19-18+deb8u10.netgear1. dpkg: error processing package libssl1.1:amd64 (--install): dependency problems - leaving unconfigured Processing triggers for libc-bin (2.19-18+deb8u10.netgear1) ... Errors were encountered while processing: libssl1.1:amd64
As the actual version has the "netgeat1" name, I guess it's sort of customized? Any thought about this?
gpaolo
Dec 11, 2020Luminary
