atomarchio
Aug 06, 2015Tutor
Interested in buying ReadyNAS for use with Tivo
I am interested in purchasing Ready NAS product for use with Tivo. Is there a ReadyNAS product that is recommended? I only have 1TB of media which is mostly MKV, AVI, MP4. Does the ReadyNAS ...
atomarchio
Aug 06, 2015Tutor
Does the ReadyNas OS6 already come with the hard drives and operating system pre-installed? I only need 2TB.
What is the part numbe I should use for ordering?
JohnRo
Aug 06, 2015NETGEAR Employee Retired
Hi atomarchio,
The harddrives are optional, there are models where harddrives are included and models that are chassis only (you can buy your preferred harddrive. NOTE: Harddrives should be part of the HDD compatibility list). The chassis of the NAS has a flash memory where it stores some of the OS, when you insert a harddrive and install the NAS it will be copied onto it. For small home networks, I would recommend the ReadyNAS 100 series and ReadyNAS 200 series.
Here's a tip when selecting a model number, for you to know which one you are looking for (in terms of size) see this naming convention:
Example: Model number RN20222D
RN - ReadyNAS 202 - 200 series 2 - 2 bay 2 - 2 TB HDD D - Desktop drives
This model contains, 2 2TB desktop drives. Total capacity of 4TB (without redundancy), 2 TB capacity (with redundancy).
Thanks,
