AQuatro's avatar
AQuatro
Is RN102 this same as RN10200?
Is RN102 this same as RN10200 ?
Is posibble to take disk from RN102 and insert to RN10200?
Will be working without loss data?
    Yes.
    AQuatro wrote:
    Is possible to take disk from RN102 and insert to RN10200?
    You can directly migrate disks from the RN102 to any OS-6 platform (including the x86 platforms like the RN422).
  • StephenB's avatar
    Yes.
    • AQuatro's avatar
      AQuatro
      Ok. It's good info for me.
      I'll buy second one.
      • Sandshark's avatar
        Sandshark
        Sensei
        Given the severe memory limitation of the 100 series, I suggest you look for at least a 200 series, which will also accept your volume with no issue (as will any OS6 NAS).  But best of luck finding one at a reasonable price.
ProSupport for Business
