Laudz's avatar
Laudz
Is SMB protocol faster than AFP ?
Hi, I am administering a large media collection and backup of work documents and family photos on an RN204 (2x8TB, 2x12TB) running 6.10.8. I've always used AFP to manage administration of content on ...
  • AnishaA's avatar
    May 11, 2023
    Hello Laudz ,
    And welcome to the NETGEAR Community! 🙂
    AFP is specifically for Apple users, if you are using MAC then using AFP is the better choice.
    If you are using Windows then we would recommend you switch to SMB but don't use both at the same time and it is recommendable since both have different execution ways.
    AFP would be slow in the Windows system if you are a Windows user you can definitely switch to SMB, if you are using both the system then also SMB is fine.
    If you are a MAC user then we would suggest you use continue with AFP.
    Also, you can refer to this kb article for better clarification.
    https://kb.netgear.com/29765/Recommendation-for-using-AFP-and-SMB-in-the-same-environment
    If your issue is resolved please close the thread by clicking "Accept as solution".
    Have a lovely day,
    Anisha A
    Netgear Team
ProSupport for Business
