Retired_Member
Jul 01, 2012Is there a list of compatible USB drives for a ReadyNas Duo?
This forum seems to be a list of problems related to connecting USB drives to ReadyNas - is there a an official list of USB drives that ARE ok to work with a ReadyNas duo ? Thanks
mdgm-ntgr
Jun 20, 2013NETGEAR Employee Retired
Well you're replying to threads that are dead which means one can assume that the issue described in the thread is resolved one way or another. Also posting in several threads makes it difficult to track what suggestions users have made to resolve an issue. Posting in threads for very different products such as the Duo v2 isn't that helpful either as USB hard disks compatible with the Duo (v1) may/may not be compatible with the Duo v2 and vice versa.
What version of RAIDiator is on your Duo?
Is your SeaGate "Expansion Portable Drive" recognised by a Linux machine (e.g. one running Debian or Ubuntu) if you hook it up to that?
