photoguy
Jul 04, 2015Aspirant
Is there a way to determine which drive goes in which slot?
I am wondering if there is a way, such as looking at the drive on a PC, to determine which slot the drive goes in? The situation is that I had a RNX6 where the 4 drives were removed to fix somethin...
krungkrung
Jul 04, 2015Tutor
labeling the disks is always a must when removing them from the bays of the chassis. If you have downloaded the logs before removing the disks that might help. In the zipped folder of system logs you will see disk smart text file, open the latest one of the one that has no date in the file name, that will show you all the info about the disks, the make, the SN, the size and which channel the disk is inserted.
