Ian_W
Jan 06, 2016Aspirant
WNAP210v2 Determine Firmware Version
Hi,
I have three WNAP210v2 access points purchased a couple of years ago, I am wanting to upgrade the firmware but I cannot find anywhere in the web config what the current firmware revision is? Where abouts is it hidden?
I need to know the current firmware so I can take the correct upgrade path to get me up to the latest revision.
Thanks in advance.
Hi Ian_W,
Welcome to the community! :)
I do not have a WNAP210v2 at the moment. However, kindly check the image below as reference (it is from a WNAP210v1) if it shows the same as with your WNAP210v2 so that you can determine the firmware version:
Hope it helps. :)
DaneA
NETGEAR Community Team
- DaneANETGEAR Employee Retired
Hi Ian_W,
Hope it helps. :)
DaneA
- Ian_WAspirant
Thanks! No idea how I missed that! Still in Christmas mode....! :smileyembarrassed:
Hi Ian_W,
You are welcome! :)
Feel free to post your future concerns here in the community. :)
Cheers,
DaneA
