Ian_W
Jan 06, 2016Aspirant
WNAP210v2 Determine Firmware Version
Hi, I have three WNAP210v2 access points purchased a couple of years ago, I am wanting to upgrade the firmware but I cannot find anywhere in the web config what the current firmware revision is?...
- Jan 06, 2016
Hi Ian_W,
Welcome to the community! :)
I do not have a WNAP210v2 at the moment. However, kindly check the image below as reference (it is from a WNAP210v1) if it shows the same as with your WNAP210v2 so that you can determine the firmware version:
Hope it helps. :)
DaneA
NETGEAR Community Team
DaneA
Jan 06, 2016NETGEAR Employee Retired
Hi Ian_W,
Hope it helps. :)
DaneA
