photoguy
Jul 04, 2015Aspirant
Is there a way to determine which drive goes in which slot?
I am wondering if there is a way, such as looking at the drive on a PC, to determine which slot the drive goes in? The situation is that I had a RNX6 where the 4 drives were removed to fix somethin...
mdgm-ntgr
Jul 06, 2015NETGEAR Employee Retired
What firmware were you running on the X6. If it is recent firmware then the order shouldn't matter but it is best to put the disks back in the right order.
If you download your logs and send them in (see the Sending Logs link in my sig) I may be able to determine the correct order.
