jonahnaylor
Sep 11, 2011Aspirant
Is there any way to set up a software RAID..? Please help.
Hi, I think I may be asking the impossible but I wanted to double check before I try swapping my hardware etc as I've spent a lot of wasted time messing about trying to set it all up. Is there a wa...
jonahnaylor
Sep 15, 2011Aspirant
THANK YOU so much for your detailed answer. It seems to not be worth it and instead i'll take your advice and instead create two backup policies to split the data over two drives roughly. It's not perfect but the alternatives seems a lot of work. Thanks again for your answer and help.
