kmassner1
Dec 05, 2018Guide
Is triple parity possible with pro 6 with raid 6
I currently have a ReadyNas Pro 6 (outgrew an ultra 4), 8 GB RAM, with a single 5 x 3TB raid volume in flexraid mode. Is there a way to add the 6th drive as parity to achieve triple parity, and thus be able to live through a 3 drive failure? I have backups upon backups going. Raid is not a backup.
Thanks, all!
- Retired_Member
Hi kmassner1, to my understanding it is not, as RAID6 gives double redundancy and would protect you against 2 disks getting faulty at the same time.
Using the NETGEAR RAID calculator you could see, that RAID10 could give triple redundancy in flexraid. You might want to check it out here:
https://rdconfigurator.netgear.com/raid/index.html
Kind regards
RAID10 would use three disks for protection, but it doesn't provide triple redundancy. There are still failure modes where two failed disks will destroy the array. So it only guarantees single redundancy, though there are multiple disk failure combinations that it can survive.
With RAID10, the disks are mirrored in pairs, so any failure mode where a disk + the corresponding mirror fails will destroy the array.
- Retired_Member
Thanks for clarification, StephenB, please let also know, whether you are aware about any RAID type available with OS6 supporting triple parity/redundancy.
Kind regards
