taceto12
Mar 21, 2025Apprentice
Issues moving a 6 disk XRAID set from a deceased Ultra 6 to an RNDP6350
Good day to all, First a little background... I have a ReadyNAS Ultra 6 that has been my backup platform to my production NAS (at home) for about 2 years. Recently it crapped out and I deter...
- Mar 21, 2025
There is nothing stored in the NAS itself regarding any configuration. All of that is on the drives, so moves with your volume.
You should boot the NAS with a scratch drive and see what OS it's running. If it's 4.2.x, I suspect it is, then you'll need to upgrade to 6.0 using that scratch drive (if I recall your PM correctly and you were running OS6 in the Ultra).
Before you do the conversion, you should upgrade the memory to at least 2GB (the memory from your Ultra6 is compatible) and back up the VPD file (see Backup-and-restore-of-VPD-file-for-legacy-ReadyNAS-running-OS6).
Mar 21, 2025Guru - Experienced User
taceto12 wrote:
It posts fine but when it comes to the part where the box starts to boot I get the message below:
ERR: could no mount root RAID d
Was this disk formatted in another device?
If this is a test disk, then you should try a factory default. Instructions are on pages 28-29 here:
taceto12 wrote:
I have a ReadyNAS Ultra 6 that has been my backup platform to my production NAS (at home) for about 2 years. Recently it crapped out and I determined that it was a hardware issue that could only be repaired by replacing a damaged hard disk back plane board. Since these are almost impossible to source out I decided to get obtain a disk-less RNDP6350 to replace it
I am thinking the Ultra was converted to OS-6 - is that the case? Do you know if the Pro-6 is running OS-4? Or was it also converted to OS-6?
taceto12
Yup, the Ultra 6 was running 6.10.10, No idea what the 6350 is running because I can't get it to come up clean...yet! 🙂
- StephenBMar 21, 2025Guru - Experienced User
Did you try the factory default using the info in the hardware manual I linked in above? The test disk needs to be installed.
- taceto12Mar 21, 2025Apprentice
Not yet Steve, I'm about to but I want to be sure I have all the info I need before doing that
