taceto12
Mar 21, 2025Apprentice
Issues moving a 6 disk XRAID set from a deceased Ultra 6 to an RNDP6350
Good day to all, First a little background... I have a ReadyNAS Ultra 6 that has been my backup platform to my production NAS (at home) for about 2 years. Recently it crapped out and I deter...
- Mar 21, 2025
There is nothing stored in the NAS itself regarding any configuration. All of that is on the drives, so moves with your volume.
You should boot the NAS with a scratch drive and see what OS it's running. If it's 4.2.x, I suspect it is, then you'll need to upgrade to 6.0 using that scratch drive (if I recall your PM correctly and you were running OS6 in the Ultra).
Before you do the conversion, you should upgrade the memory to at least 2GB (the memory from your Ultra6 is compatible) and back up the VPD file (see Backup-and-restore-of-VPD-file-for-legacy-ReadyNAS-running-OS6).
taceto12
Yup, the Ultra 6 was running 6.10.10, No idea what the 6350 is running because I can't get it to come up clean...yet! 🙂
Mar 21, 2025Guru - Experienced User
Did you try the factory default using the info in the hardware manual I linked in above? The test disk needs to be installed.
