Steelbeak
May 16, 2022Aspirant
Issues with ReadyNAS 2 Duo / RND2000 v1
Hi, So I'm trying to get my old ReadyNAS 2 Duo / RND2000 up and running after its been collecting dust for far too long. It did have trouble right from the get go with booting properly. So, at th...
May 16, 2022Guru - Experienced User
72+ hours is not normal. Per the manual, the status suggests that the system is trying to boot or shutdown. See page 22 here: https://www.downloads.netgear.com/files/GDC/RND2110/Duov1_NV+v1_HW_en_06Dec11.pdf
I suggest using RAIDar - if it can find the NAS, it could give more useful status. https://kb.netgear.com/20684/ReadyNAS-Downloads#raidar
Steelbeak
Hi again,
I have been using RAIDar from the start (sorry for not mentioning that in the earlier post) and whilst the NAS is in the current "mode" (whatever it's doing at the moment), RAIDar is unable to detect it. My router isn't registering anything either, only my phone and computer is connected according to the router.
