gso
Apr 14, 2020Guide
iTunes sync
Currently I have my iTunes music files on the NAS. I manually copied them to the music folder in ReadyCLOUD. My main source for these files is in my iTunes/music folder on my Mac. The music is outdat...
Apr 17, 2020Guru - Experienced User
gso wrote:
I'm "scanning library" now in the Plex app. I that the same as "rebuilding?
Yes.
After that you might need to fix some of the matches.
gso
Apr 17, 2020Guide
Thx, I'll keep an eye out for it. Don't know why I'm doing everything thru Readcloud. Wasn't aware of alternatives when I got the NAS. A bit over my head at the time. I'm still running TimeMachine thru the app (the next time it won't back up I'll try not using Readycloud) but doing everything else with third party apps now. Thanks for the help.
