Franceschinl
Sep 04, 2018Tutor
JDownloader 2 Readynas
Hi, it is possible install JD2 on rn104? Have you a guide to install it? Thanks
- Sep 05, 2018
Hi @Franceschini
Welcome to the Community!
Not sure JD2 can be installed as I haven't tried it myself but I came upon a thread on installing JD.
This might be possible as well with JD2. Here is the link.
NOTE: NETGEAR does not warrant any third-party app.
If you have contact with the developer it would be a good way to talk to them.
Hope this helps!
Regards
Marc_V
Sep 05, 2018NETGEAR Employee Retired
Hi @Franceschini
Hope this helps!
Regards
