TechZ1's avatar
TechZ1
Kingston KVR333X64SC25/1G 1GB DDR1 / PC 2700 / DDR 333
Just bought 1x 1GB stick of Kingston Value RAM,
Model: KVR333X64SC25/1G
Type: SO-DIMM
Shows up perfectly as:
Memory: 1024 MB [2.5-3-3-7]
NAS: ReadyNAS NV+ [X-RAID]
Firmware: RAIDiator 4.1.7 [1.00a043]
Ran the onboard mem test app twice and passed.
  • ChrisMc73 wrote:
    Ok, so is there a stick that does for sure still work, today?
    +1
    We've learned that the old Kingston KVR333X64SC25/1G worked, but not the new ones, because they changed something.
    And the old Corsair VS1GSDS333 worked, but not the new ones, because they changed something.
    And from another thread, that the old Patriot Signature 1 GB SODIMM PC-2700 DDR-333 Memory Module -PSD1G33316S worked, but not the new ones, because they changed something.
    Right now I'm trying to find the status on the Crucial CT12864X335 ... and from searching this forum, I can't find anything that indicates that it won't work. So I'll put my money on this one.
    Type: SO-DIMM
    HI, I'm planning to upgrade my NV+.Cound you share some advice with me?
    My mem module shiped with my NV+ is of DDR400( I bought it early this year from amazon) and it works at 2.5-3-3-7 too!
    I am so focused with the type of modules, dose it mean NV+ support either of them or DDR 333 is just enough.
    Thanks.
  • Hi,
    Here is a HW compatibility list from Netgear about ReadyNas, it is not recent but have all compatible memory models listed.
    http://www.docstoc.com/docs/35858999/readynas-Hardware-Compatibility-List
    Eric
  • He is the details from an other site
    http://readynas.su/compatibility_list/memory/
    ReadyNAS NV/NV+/Duo
    Можно использовать модули 200 pin DDR SO-DIMM. Инструкции по замене памяти в ReadyNAS NV/NV+ размещены здесь.
    256 MB
    ■Aeneon PC2700S-2533-1 DDR333 CL2.5 256MB (8-Chip)
    ■Aeneon PC3200S-3033-1 DDR400 CL3 256MB (8-Chip)
    ■Apacer PC3200 CL3
    ■Infineon HYS64D32020HDL-6-C (8-Chip)
    ■ADATA ADFDB280400H (4-Chip) (added 5/15/06)
    ■VDATA Memory Expert VDFDB28040AH DDR333(2.5) 256MX4 (4-Chip)
    512 MB
    ■Apacer PC3200 CL3
    ■Infineon HYS64D64020HDL-6-C (8-Chip)
    ■Kingston KVR400X64SC3A/512
    ■VDATA Memory Expert VDFDB290804H DDR333(2.5) 512MX8 (8-Chip)
    1 GB
    ■Apacer PC3200 CL3
    ■Kingston KVR400X64SC3A/1G
    ■Patriot 1GB 200-Pin DDR SO-DIMM DDR 333 PEP1G2700SLL(PC 2700)
    ■Wintec PC2700-1G/Micron (#38299682) 2 RANK (16-Chip)
    ■Wintec PC3200-1G/Micron (#38290682) 2 RANK (16-Chip)
    ■Wintec PC3200-1G/Qimonda (#38290681) 2 RANK (16-Chip)
    ■Hynix HYMD512M646CFP8-J (16-Chip)
    ■I-O Data AP-SDD333-1G (16-Chip) MT16VDDF12864H)
    ■Crucial CT12864X335 (16-Chip 1GB) (Micron’s MT16VDDF12864H)
    ■NETGEAR 1GB SODIMM for NV/NV+ (16-Chip)
  • I leave this note as future reference and potential memory upgraders:
    I have two NV+ running with Radiator 4.1.8.
    One, I was able to sucessfully update with 1GB RAM (Kingston KVR333X64SC25/1G). Memory test was passed successfully more than 4 times. The unit is runing smoothly.
    The other one will pass the memory test (so far 5 or 6 times). But now the unit hangs while booting. First the blue power-LED will start to flash more slowly, then it will freeze - either off or in any of the intermediate on stages. THe display shows "Booting". The unit still works fine with the 256MB RAM.
    I guess it only shows again what a gamble the memory upgrade is ... :shock:
  • Thank you SO much for posting this. I've had a ReadyNAS NV+ for about 5 years and ever since I upgraded the memory to a 1GB module from Crucial I had terrible performance (in FrontView, moving files, etc.). I just replaced my memory module with this specific Kingston module and BANG! everything is working perfectly. This means I don't need to spend $$$ to buy a new device (from Synology) -- at least, for a little while longer. I only wish I would have found this post earlier -- it would have saved me so much frustration and angst.
  • The 1GB Kingston KVR400X64SC3A/1G SODIMM in my NV has died. When I upgraded from 256MB, I kept the OEM SODIMM, so I could revert to that, but I also have one stick of Kingston KVR333X64SC25/1G I bought a few years back.
    I tried out the KVR333 (which isn't on the HCL) when I first bought it, but the NAS was having periodic lockups so I replaced it with the KVR400 (which is on the HCL). It's run flawlessly ever since but it was the KVR400 that failed last night.
    I had kept the KVR333, and used it to diagnose the failed KVR400. The NAS is running fine on the KVR333 at the moment, showing timings of [2.5-3-3-7]. I don't fancy having any more graceless shutdowns, but I'd also rather be on the 1GB SODIMM than the OEM 256MB.
    So long story short, the lock-ups I was having with the KVR333 were five years (and many RAIDiator revisions) ago. And five years on, you guys seem to be having good success with the KVR333. Is it possible that those lock-ups might have been related to the old firmware, and that the new RAIDiator(s) cure the problem I was having earlier with the KVR333?
    If there is no correlation, which is to say the lock-ups had nothing to do with the version of the firmware, I'd sooner go back to the OEM 256MB SODIMM and not risk any data corruption. Yeah, I could just wait and see but you only get to dodge the bullet so many times before it finally hits you in the tooches, and I'd rather not risk it.
    TIA for your advice.
ProSupport for Business
