owentje1
Jul 22, 2009Aspirant
KVR400X64SC3A/1G 1GB
I have tried two of these in my NV+. The result was a non booting NV+. This memorymodule should be removed from the compatibility list. The user 'geekstarpilot' experienced also the same problem with this module. On the internet are more posts regarding this module using the Readynas DUO (also with problems).
So I do not recommend using this (I guess the current revision is somehow a bit different compared to the ones which other users are using with success)
- GnagmanAspirantHave the same problem, the KVR400x64SC3A/1G does NOT work. Remove it from the compatibility list.
- OptikAspirantJust encounted the very much earlier comments about this. By accident found positive views about this memory module (well before I found this info) - so installed on NAS Duo 2 x Tbye RAID 4.1.7 setup - has functioned perfectly from the off - now been running continuously for 5 months. Don't know the cause of the problem with higher spec NASs.
