dabrain22
Apr 03, 2012Aspirant
Lack of Hard drives on HCL
The HCL list for hard drives is very small looking at the 3TB drives there is only like 3 drives on the list. A fast look at what 3TB drives are available below. Seagate Barracuda ST3000DM001 3TB 7...
PapaBear1
Apr 27, 2012Apprentice
As to the 4TB disks, there is only one listed on Newegg (Hitachi). Some have tried that one and some have removed some 4TB drives from the enclosures (Seagates purchased as external drives). The Seagates will not be tested as they are not intended for use in a RAID or desktop. Only bare drives available to the public will be tested. TeknoJnky did the tests of the Seagates last fall and had no problems. The ST4000DX000 which at that time was only available in an enclosure is now listed on Amazon as a bare drive for $350, but is not listed on Newegg.
Another member, put 6 Hitachi HDS724040ALE640 in his Pro Business Edition and says he is not having any problems, but this is not the drive available on Newegg (H3IK40003254SW) but is listed on Amazon by it's Hitachi PN of 0S03364 (note: Hitachi uses an opaque silvery anti-static bag with only the PN on the outside, but only the drive model on the actual drive label. Netgear uses on the drive model and sometimes if they are advised, they will put the PN in the comment block. For example the HDS5C3030ALA640 is available under three different PNs, one for retail packaging and two for OEM bare drive packaging.
