dsnpevl
Jan 02, 2015Virtuoso
LeafNets IP address in 5.187 range?
Hi forum, Lately I am seeing a strange IP address popping up when I do ifconfig, related to the LeafNets network adapters. It's in the 5.187.xxx.xxx range, that is nowhere in my ISPs address range....
TeknoJnky
Jan 02, 2015Hero
its part of the netgear/readynas vpn client (readynas remote).
5.187 used to be part of a reserved block of ips, however some time in the last couple years, the ips have been released for public use, so the remote ips can conflict with real world ips.
my guess it probably won't change until remote is converted to ip6.
you can remove readynas remote from your pc if its on the same local network, however if you are on a remote desktop/laptop and want remote access to your readynas, you will need to enable that ip/network.
