dsnpevl
Jan 02, 2015Virtuoso
LeafNets IP address in 5.187 range?
Hi forum, Lately I am seeing a strange IP address popping up when I do ifconfig, related to the LeafNets network adapters. It's in the 5.187.xxx.xxx range, that is nowhere in my ISPs address range....
Jan 02, 2015Guru - Experienced User
Correct.
dsnpevl wrote: The PC is on the same local network as the NAS. So if I understand you correctly, that wouldn't really need to have readynas remote. But on a mobile device or a remote PC outside the LAN, it would be needed if I want to connect to the NAS.
Though there are other ways you can reach your NAS over the internet. If you find remote doesn't work for you, you can use FTPS or HTTPS instead. The alternatives require a bit more setup, and you do need to be careful to choose good passwords.
