neiloakley
May 26, 2020Guide
lifesupp on Netgear ReadyNAS NV+ v2
It finally happened - I have the dreaded lifesupp message. I've powered down the unit to hopefully preserve whats there. 3 x 5TB Seagate drives XRAID2 (RAID5), started to get warning messages ab...
May 26, 2020Guru - Experienced User
neiloakley wrote:
I have a suspicion 2 out of the 3 drives have failed so i'm not holding out much hope.
Try connecting them to a Windows PC (either sata or usb) and testing them with Seatools (using the long test). Label them by slot as you remove them from the NAS.
neiloakley wrote:
Would 3rd party RAID recovery software work? Something like R-Studio. Or could Netgear Tech help to confirm if this is something recoverable? It's a very old unit so well outside of any warranty or support period.
- Netgear does offer a data recovery service: https://kb.netgear.com/69/ReadyNAS-Data-Recovery-Diagnostics-Scope-of-Service
- R-studio is an option.
- If the disks are reasonably intact, you could try cloning them.
Though you haven't asked, it's best to get NAS-purposed replacement drives (in particular, don't get Seagate DM drives). 5 TB isn't popular now, so you'd need to move up to 6. In this size range, Ironwolf drives are a better choice than the WD EFAX drives.
- neiloakleyMay 26, 2020Guide
StephenB wrote:Try connecting them to a Windows PC (either sata or usb) and testing them with Seatools (using the long test). Label them by slot as you remove them from the NAS.Thanks - running 'Long Generic' test on the first drive now. Might take a while!
- neiloakleyMay 27, 2020Guide
Disk 1 (Bay 2)
Short test: Pass
Long Test: Fail after 10 minutes (Code F167CCDB)
Disk 2 (Bay 3)
Short test: Pass
Long Test: Pass (10 hours)
Disk 3 (Bay 4)
Short test: Pass
So i'm hopeful that I can still recover the data from the 2 working drives, but why would the NAS suddenly not be able to mount the volumes?
If i try any sort of error correction to recover bad sectors on disk 1, will that risk further data loss?
If i go ahead with R-Studio, should I mount all three disks into a virtual raid, or just the 2 functioning disks?
The errors on NAS boot are as follows:
_________________________________________________________________
***** File system check performed at Tue May 26 10:25:31 GMT 2020 *****
fsck from util-linux-ng 2.17.2
fsck.ext4: No such file or directory while trying to open /dev/c/c
Possibly non-existent device?The paths for the shares listed below could not be found. Â Typically, this occurs when the ReadyNAS is unable to access the data volume.
Documents
media
backup
[Tue May 26 10:26:17 GMT 2020]_________________________________________________________________
- StephenBMay 27, 2020Guru - Experienced User
You could try rebooting it with the failed disk removed, and see if that works. Use the boot menu to skip the volume check (pages 24-25): http://www.downloads.netgear.com/files/GDC/RND2110/ReadyNAS_Duov2_NV+v2_HW_en_23-Mar-12.pdf
Or just go right to R-studio. I'd start with just the two functioning disks.
Likely it would, and if the two remaining disks are healthy I think you are better off just using those two.
