janpeter1's avatar
janpeter1
Luminary
Jun 27, 2015
Likely Readynas 3-series
Hello, I plan to upgrade from my ReadyNAS Duo that served me well for 5+ years running 2x2TB in Raid 1. Consider to buy 2- or 4-bay (or even 6-bay hope not) NAS and it is for home use with small o...
  • StephenB's avatar
    Aug 04, 2015
    You could put a suggestion in the Feature Request & Feedback subforum.
    You could also make a request at rnxtras.com (not a netgear site)
ProSupport for Business
